need HELP! im doing a auto to manual swap on my prelude
i have a 1997 honda prelude automatic(tiptronic), now im swaping in a 93 jdm h22A with a manual lsd tranny. is it possible for me to use the automatic obd2 wiring harness? i already have a obd2 to 1 conversion harness already.
By the way how can i get the Reverse signal light to go on with this new engine when i put it on reverse?
Thank you in advance for your help.
bump help this guy yea hes wants to know if he could reuse the obd2 auto harness on his obd1 jdm h22A motor and still use the p13 obd1 ecu so to run obd1 what does he have to change ?
http://www.mazmo.com/zameoj/swap.htm
At the very bottom of the page it shows how to wire up the clutch lock-out switch and reverse lights. Im in the process of doing this as well, so if you run into anything different or have any hints, post them up!
yes it is possible, we had to splice every wire though so i dont suggest it there is alot of work to be done when u do it,and i also suggest going to HONDA to get some ecu plugs dont go into the ecu a soder the wire onto the plug mine works fine like that but it would so much easier if u got some ecu plugs
and if u need anything else i should be able to help u, i have a 92 prelude si that was a auto i did a manual swap with a h22a and lsd just like u.
screen_name
Engine Management and Tuning
Jun 11, 2010 11:47 PM
