Hondata Gasket
Old Feb 21, 2002 | 07:39 AM
Hayasa15's Avatar
Default Hondata Gasket
I am considering using a hondata gasket. Are they any downsides to it? I dont drive my civic in the winter so a cold start isnt a problem. Is the performance worth 60 dollars? What does a honda gasket cost in comparison?
Old Feb 21, 2002 | 08:07 AM
Spade's Avatar
Default Re: Hondata Gasket (Hayasa15)
The hondata intake manifold gasket is made to decrease intake manifold temperatures.
A stock honda intake manifold gasket can be purchased for $6.23 + shipping from http://www.hondaautomotiveparts.com/...NIFOLD+%282%29
NOTE: Price quoted for a 2000 Honda Civic HX.
Old Feb 21, 2002 | 08:58 AM
rainforest's Avatar
Default Re: Hondata Gasket (Spade)
no man, dont worry about the cold starts your car will still regulate that from the fast idle valve.
Old Feb 21, 2002 | 09:00 AM
Eggman's Avatar
https://honda-tech.com/zerothread?id=128350
Old Feb 23, 2002 | 07:36 PM
Hayasa15's Avatar
Default Re: Hondata Gasket (Eggman)
But could i get the same results my disconnecting the hoses to the manifold and tbody?
Old Mar 1, 2002 | 07:59 PM
Notorious BAE's Avatar
Some info on IM gaskets in general:
http://home.san.rr.com/scmorgan/spacers/Theory_FAQ.htm
Old Mar 5, 2002 | 07:53 AM
Hayasa15's Avatar
Default Re: Hondata Gasket (Notorious BAE)
Old Mar 5, 2002 | 01:48 PM
VTEC4GS's Avatar
no, the intake manifold heats up due to head temperature and due to underhood engine bay temps ... disconnecting the coolant from the t/b and manifold will just cause your idle to fluctuate annoyingly.
The hondata gasket is made out of delrin which the V8 guys use so there is less heat transfer ... in theory ... no experience whether it actually does anything, my inclination is to try it since it can potentially cool the fuel too ... btw, fuel rail is separated by a type or cork to not conduct heat so anything helps.
Greg
Apr 7, 2009 08:04 AM
huevosrancheros
Oct 14, 2006 09:33 AM
HondaPH22
Jul 10, 2006 05:42 PM
ThinHoanG
May 25, 2005 05:58 AM
nickwilmot
Oct 17, 2003 01:58 PM
