HELP ME!!!im under my car right now..(exuast)(shortshifter)
ok, im currently trying to install a short throw shifter, i can drop the whole shift part out. but the exuast is in the way. Im working right near the cat. main question. How do i remove the hook on the exuast from the rubber that holds on to it? its a 97 civic hx.
PLEASE HELP ME!!!! im waiting for someone right here to answer this.
use a little bit of grease or lube of some sort and just work it off. wow that sounds really wrong but i hope it helps
Unbolt the exhaust from the header downpipe. Spray some wd40 on the rubber hanger by the resonator and slide it off the hook. Then just let the exhaust hang while you remove the linkage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wadup »</TD></TR><TR><TD CLASS="quote">Unbolt the exhaust from the header downpipe. Spray some wd40 on the rubber hanger by the resonator and slide it off the hook. Then just let the exhaust hang while you remove the linkage.</TD></TR></TABLE>
Do you absolutely have to unbolt the exhaust? Or can you skip this step?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atmosphere »</TD></TR><TR><TD CLASS="quote">ok, im currently trying to install a short throw shifter, i can drop the whole shift part out. but the exuast is in the way. Im working right near the cat. main question. How do i remove the hook on the exuast from the rubber that holds on to it? its a 97 civic hx.
PLEASE HELP ME!!!! im waiting for someone right here to answer this.</TD></TR></TABLE>
When i did that exact same thing, i just wedged a screw driver into the hole of the rubber grommet and then backed it back out by wedging and prying. Its a biznatch but it will take you 3 - 5 min at MOST. funny part is that it slides right back on once your done.
i had hell with putting in my short shifter but i have skinny *** hands..lol
yep use a lil wd40 it should come off
Do you absolutely have to unbolt the exhaust? Or can you skip this step?[/QUOTE]
ubolting the exhaust would make installing the short shifter a lot easier because there wont be anything in your way. once the exhaust is removed, you will be able to swing the shiftlinkage down (it should swing freely) to the ground and work from there. gluck
atmosphere
Aug 8, 2005 12:04 PM
