battery offset for 700cc siemens injectors for aem...anyone know???
hey all, does anyone know the battery offset for siemens 700cc injectors? my car keeps stalling out with aem ems once the rad fan kicks in and i have to restart it and it drives fine again til the fan shuts off and comes on again. my tuner has been reading the aem ems forums and says he needs the battery offset for these injectors ..thanks
I hate to say it but your probably going to have to send off your injectors to AEM unless you can find someone with the battery offset settings. Good luck.
I highly doubt that your problem will be fixed with setting up your battery offset map.
Have your tuner setup your idle rpm vs % pw map again. Make sure that your headlights and any other accessories are on first, and then set it up so that the idle learned value is around -10%. This will make it overshoot your idle at first and lower it from there.
You can also try advancing the timing below your lowest target idle in the map and/or advance the timing when your idle error is negative (there's a table for this in the advanced idle area)
You also may need to simply up your idle rpm... what's it set at now?
vaporboy12
Jul 24, 2006 03:09 PM
