Check out my pad
Old Aug 7, 2005 | 06:49 PM
JDM Factor's Avatar
Default Check out my pad
I just opened my Spec VR's from the package today. The two pads were kinda stuck together from the wrapping being so tight. Anyways, I was going to still put the pad on, however when I looked at the pad, it looks like a little chunk of the material might come off during braking. Check out the pad. I'm sure it's nothing I just wanted some other opinions.
Old Aug 7, 2005 | 06:54 PM
Bbasso's Avatar
Default Re: Check out my pad (JDM Factor)
Personally, i'd call andie at cobalt and show/ask.
Mythias's Avatar
Don't install them. Contact the cobalt distributor first about replacement. If that doesn't work, then contact cobalt friction directly.
Old Aug 7, 2005 | 07:19 PM
JDM Factor's Avatar
Do you guys see what I mean though?
Old Aug 7, 2005 | 07:32 PM
JDM Factor's Avatar
I just e-mailed Andie, Dammit! I was almost done with my brake install! Well..better safe than sorry i guess.
Old Aug 7, 2005 | 07:33 PM
nightrider's Avatar
Default Re: (JDM Factor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys see what I mean though?</TD></TR></TABLE>
definitely noticeable.
Old Aug 7, 2005 | 07:44 PM
Ron M's Avatar
Your better off contacting Cobalt, i wouldnt take the chance of something happening
Old Aug 7, 2005 | 07:46 PM
.water's Avatar
ya dont install them yet..if you install them and use it they will just say its ur problem..good luck with replacement
Old Aug 7, 2005 | 08:12 PM
Chris F's Avatar
Default Re: (RonnieDC2)
Personally, I'd put the ******* on and BRAKE!
Still, let Andie know, see what he thinks, maybe get a better picture? Maybe you can get a credit towards your next set.
Apparently, <U>this</U> is a normal wear pattern for Cobalt. No matter, I have a set on my car and a set in the toolbox.
Old Aug 7, 2005 | 08:39 PM
JDM Factor's Avatar
Default Re: (Chris F)
Hahaha only you could do such damage to pads! I guess mine (single) pad isn't bad after all. I ended up e-mailin Andie, see what he says, besides it's only a 1/2 hour away from the house to Cobalt.
Old Aug 7, 2005 | 09:33 PM
midwesta's Avatar
i see it and agree with others, have them look at it.
Old Aug 7, 2005 | 09:40 PM
hayabusa160's Avatar
try and get a macro shot of it so everyone can see better of how it looks and how much actually was taken off the pad.
Old Aug 7, 2005 | 09:44 PM
Opie's Avatar
They are new pads and Andie is a good person with a rep to uphold. I would contact Cobalt and let them know
Old Aug 7, 2005 | 09:56 PM
uNF$@#!'s Avatar
Chris
those look like the older spec VR's where people have mentioned there seems to be problems with the brake material coming off the backing... but andie has taken care of anyone with this problem.
the newer ones, the one with the blue backing seem like the issue isnt so predominant.
the upper left picture you show seems more of a stuck caliper pin issue.
Old Aug 8, 2005 | 03:58 AM
Chris F's Avatar
Default Re: (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">those look like the older spec VR's where people have mentioned there seems to be problems with the brake material coming off the backing... but andie has taken care of anyone with this problem.</TD></TR></TABLE>
These were purchased late last year.
The top right one was on the same side as the one with the backing plate that came off, hence the funny wear pattern.
Old Aug 8, 2005 | 09:12 AM
JDM Factor's Avatar
I tried to take some better pictures today here ya go.
Old Aug 8, 2005 | 09:13 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Personally, I'd put the ******* on and BRAKE!
they are a wear item...
Old Aug 8, 2005 | 12:49 PM
JDM Factor's Avatar
I ended up goin down to Cobalt and exchanging them. I would have said F**K it but Sebring isn't a track to not have good brake pads!
Old Aug 8, 2005 | 06:28 PM
Nishant's Avatar
it was taken care of...and yes better to be safe on a track than to be sorry later
bad-monkey
Honda Motorcycles
Jan 5, 2007 10:37 PM
Bbasso
Nov 17, 2004 07:40 AM
98cwitr
Aug 13, 2004 04:26 AM
optikal_blitz
Jul 18, 2003 09:07 AM
Regular Series
Nov 25, 2002 04:03 PM
