which is better high or low compression?
Old Aug 7, 2005 | 05:40 PM
rollercosta123's Avatar
Default which is better high or low compression?
hey guys i have a 95 gsr and want to build my motor to do high compression with nos. i am not interested in turbo or anything. i want to have atleast 240 hp on the block itself and i want to build my head with skunk 2 stage 3 internals. i think that this is better than a turbo so what do you think? let me know please.
Old Aug 7, 2005 | 07:00 PM
allmotoralldayeveryday's Avatar
Default Re: which is better high or low compression? (rollercosta123)
id use a neptune with itr internals youd be runin pretty strong if you went that root tha neptune soft ware is a bad *** i had it in my 90teg i had swaped a b16 in that i was planin on ctr internals but never had the chance to install them
Old Aug 7, 2005 | 07:03 PM
Civic4less's Avatar
Default Re: which is better high or low compression? (allmotoralldayeveryday)
Well if you're planning on NOT going turbo. And doing all motor. Then you would want higher compression. Good luck on your build.
Old Aug 7, 2005 | 07:14 PM
blackbmagic's Avatar
Default Re: which is better high or low compression? (Civic4less)
well u would def get more power with turbo but if ur gonna go high compression n/a with nitrous ur gonna have to get a real good tune because high compression and nitrous can be a dangerous mix to ur engine with an improper tune...its safer with low compression but u will find u will have ganed much more power if u build it right with high compression....imo N/A is nice if u go all out and do ur engine up but if not turbo is the way to go
Old Aug 7, 2005 | 07:29 PM
Chez'sExCoupe's Avatar
Default Re: which is better high or low compression? (blackbmagic)
NOS works much better with a turbo app. if your intent on getting NOS go turbo (spraying into your intercooler produces good results). High compression plus NOS is dangerous and requires very fine tuning which will end up getting very expensive.
Death_to_Thieves
Apr 24, 2004 08:46 PM
UTI tunin
Sep 25, 2002 12:52 PM
baonest
May 7, 2002 10:31 PM
dontcare61776
Apr 7, 2002 09:27 AM
charjacq
Dec 12, 2001 03:35 PM
