2001 HONDA ACCORD, ECU ISSUE, HELP
Old Aug 7, 2005 | 03:38 PM
rhinotechie's Avatar
Default 2001 HONDA ACCORD, ECU ISSUE, HELP
Hi I have a
2001 Honda Accord Coupe,
4 Cyl,
Auto, with California emissions.
Recently I started to get the P1456 code, after it came back the second time around I checked around and found the code to be one of the following:
* Gas Cover is loose (not so)
* EVAP control unit
* Manufacturer Controlled Auxilary Emissions Control System
So I brought my car to the local mechanic specializing in engines and trans. After checking the car with his OBDII tool he received almost 3 pages of possible causes for the problem. He went through the items on the list isolating it to a few components and placed the order with HONDA expaining the code and the parts he needs. Honda replied with a fax saying that this particular model DOES NOT have the problem with the relays that he found, but rather the ECU is faulty and needs to be replaced...
Now that's all fun and games except for the cost of the unit, from what i was told, the California emissions ECU will cost me about $800-$1000. According to the manual the car has the warranty for the ECU for 8years or 80,000 miles (whichever comes first). What is funny is that I am at 79,495 miles.
Does anyone have any advice for me, has anyone else had experience with ECU problems, and such CLOSE CALL break downs. The reason i ask is my father has an AUDI and the dealer did everything they could to not repair the car. All feedback is appreciated...
thanks,
~Artem
Old Aug 7, 2005 | 03:57 PM
bill-71SS's Avatar
Default Re: 2001 HONDA ACCORD, ECU ISSUE, HELP (rhinotechie)
most the time it is a faulty gas cap,possible ecm,you are still under warranty,take it in.
Old Aug 8, 2005 | 04:47 AM
Duane_in_Japan's Avatar
My advice is that emission problems are covered by some very long warrantees, go get your free computer.
Old Aug 8, 2005 | 04:53 AM
Default Re: 2001 HONDA ACCORD, ECU ISSUE, HELP (Duane_in_Japan)
Try these for fixes, tighten gas cap, you should make sure they click three times to be sure they are tight, they could still be bad though, shops that are up to date, the dealer can pressure test it, you must use an OEM cap.
The 2 way valve is filled with gas, dont ask me what the 2 way valve is, they will know.
Remove and replace the evap bypass solenoid, 2 way valve, vent SOV & solenoid.
If they want to give you a free computer because the company will pay for it and then do this other work later for free too then let them go for it.
sussnk
Feb 27, 2015 03:52 PM
zippyguitarist
Dec 23, 2013 07:03 AM
Jocelyn
Nov 19, 2011 05:53 PM
ironnie7i
Jul 17, 2006 05:29 PM
nathanie1
Oct 19, 2005 04:54 PM
