Transmission Jerk Question
Old Aug 7, 2005 | 02:09 PM
97akwerd's Avatar
Default Transmission Jerk Question
I accidentally posted this in the prelude section...
My car done this for months, and I just wanted to see if anyone knew what it was...
Whenever I shift from Park to Reverse or Park to D3 etc, the car waits a second then has a notiable jerk. My transmission was rebuilt a little over a year ago, but the shifts are pretty good. Is there any reason it does this? It's very noticable when i go into Reverse almost seems like a clunk, could this be my motor mounts?
Everything else seems fine other then this hard clunk when enganging in gears. I change tranny fluid every oil change (yes its a little overkill, but i figure its only about 3.00/bottle)
Old Aug 7, 2005 | 02:24 PM
yellowdcn's Avatar
Default Re: Transmission Jerk Question (97akwerd)
This happens to me all the time if I do not warm up the car in the morning. If that happens in the morning, I been told that the transmission fluid has to thin out or something? This only happens when the temp of the car is low?
Old Aug 7, 2005 | 02:43 PM
97akwerd's Avatar
Default Re: Transmission Jerk Question (yellowdcn)
Well I do notice it happens not as severe if I let the car fully warm up and hold the brake pedal all the way down but it still jerks a little, I just wanted to make sure this way ok? My transmission was rebuilt a little over a 1.5 year ago.
Old Aug 7, 2005 | 02:50 PM
P_Adams's Avatar
I've two (2) '97's and they both exibit this condition. I've a hunch that the TCM is programmed for this considering how many people have commented on this. I've been lead to believe that this was an effort by Honda to avoid damage to the trans from engaging forward directly from reverse before the car stopped rolling (and visa versa)
Perhaps this is just conjecture, but dispite all the gear clashing that I've heard in "88"s and "89's (I owned one each), I have not heard of any in the later generations.
P
Old Aug 7, 2005 | 03:26 PM
Stealthman80's Avatar
Default Re: Transmission Jerk Question (P_Adams)
my 93 does that aswell, it shifts pretty hard into reverse but usualy noware near as hard into D, I took it to a tranny shot a couple of weeks ago and they said my tranny was a ok, didnt see anythgin wrong with it.
Old Aug 7, 2005 | 03:42 PM
97akwerd's Avatar
Default Re: Transmission Jerk Question (Stealthman80)
Ya I think mine is the same way also alot harder into reverse, then into drive...I actuall have a 97 2.2CL but I figured everything is the same on the accord, so why not just ask here. You guys are great...
Old Aug 7, 2005 | 05:24 PM
P_Adams's Avatar
...and as we all ride off into the sunset, with the light reflecting off our white hats...........
LOL
Not a problem. Sometimes we do get it right
Old Aug 7, 2005 | 05:41 PM
cottonfamily05's Avatar
my 93 does that too. i think my mounts are shot tho
Old Aug 7, 2005 | 05:50 PM
P_Adams's Avatar
Default Re: Transmission Jerk Question (ejc3110)
... probably not the same condition
If the engine vibrates excessively and feels like it's slam dancing under your hood when you put it in gear; you're probably correct about the mount.
My wifes' accord would shake so bad that the front bumper cover and steering wheel would vibrate by itself!! (and it had but one broken mount.)
Old Aug 7, 2005 | 07:16 PM
mine just appear to be worn out. at least the tranny in the front
Old Aug 7, 2005 | 07:53 PM
lilman4o8's Avatar
it's normal with accords, if you double check your mounts and it's good, don't worry much. but changing your tranny fluid everytime you change your oil, i don't think it's a good idea. sometimes you have to let the fluid work in. like for synchromesh fluid, you have to let it work in. i'd recommended to use synchromesh fluid.
Old Aug 7, 2005 | 08:31 PM
97akwerd's Avatar
Default Re: (lilman4o8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilman4o8 &raquo;</TD></TR><TR><TD CLASS="quote">it's normal with accords, if you double check your mounts and it's good, don't worry much. but changing your tranny fluid everytime you change your oil, i don't think it's a good idea. sometimes you have to let the fluid work in. like for synchromesh fluid, you have to let it work in. i'd recommended to use synchromesh fluid.</TD></TR></TABLE>
Oh someone told me it was a good idea to change it every oil change to always have fresh fluid? I didnt think it would be bad damn i can't do anything right with my car
Old Aug 7, 2005 | 08:48 PM
P_Adams's Avatar
Default Re: (97akwerd)
Considering we're working with an AUTOMATIC transmission here, I would strongly suggest staying with Honda ATF fluid if you're going to do a transmission service.
With regards to the interval of changing the ATF fluid: unless the transmission requires repair or indicates overheated fluid or other such incident, those intervals are far too frequent. (and way too expensive)
Honda recommends it at 60,000 mile intervals ) depending on year/model; and that works out quite well.
As far as your comment
"I didnt think it would be bad damn i can't do anything right with my car"
Relax, we've all had to learn along the way and you will too.
It just doesn't help when you get recommendations like that.
jmai86
Jul 6, 2012 03:39 PM
slideintegra08
Honda Civic (2001 - 2005)
Jan 5, 2011 10:19 PM
Duck Sauce
Apr 29, 2008 11:34 PM
Vermont
Jan 28, 2007 02:14 PM
Alibi86
Aug 23, 2005 10:33 PM
