Weird Check engine light issue **did a search**
Old Aug 7, 2005 | 09:42 AM
OshkyCiv23's Avatar
Default Weird Check engine light issue **did a search**
Ok, here is the quick rundown. I have my friends car which is a 99Si with Jackson Blower...Hondata s200 running about 10psi. The injectors are RC saturated 550's and this is where the problem started. He installed the injectors with the clips and he used these shitty *** wire splicers to connect them. Needless to say they went bad and the car was in limp mode because one of the injectors was constantly grounded out..and just help wide open.
I Re-wired all the injectors and everything is fine now. BUT!!! The check engine light comes on after 2300+ rpms, and then goes back off when the car comes down to idal... Any suggestions?>???
Modified by OshkyCiv23 at 11:37 PM 8/7/2005
Old Aug 7, 2005 | 02:54 PM
OshkyCiv23's Avatar
Default Re: Weird Check engine light issue **did a search** (OshkyCiv23)
HELP!!!
Old Aug 7, 2005 | 05:20 PM
OshkyCiv23's Avatar
help again?? C-mon... I know someone here has an idea!!
Old Aug 7, 2005 | 05:40 PM
1slowhatchie's Avatar
have you checked the code that it's throwing yet and did you try resetting the ecu?
Old Aug 7, 2005 | 06:04 PM
OshkyCiv23's Avatar
Default Re: Weird Check engine light issue **did a search** (1slowhatchie)
checked code...and check engine light just stayed on.
reset the ecu by disconnection by holding battery cables together for 25 seconds....till on
flipdrift
Mar 5, 2009 05:04 PM
AndyD
Mar 17, 2005 06:06 AM
redludevtec
Aug 15, 2004 04:00 PM
xcathodex
Mar 20, 2003 07:44 AM
PotatoePAPA
Mar 8, 2003 11:45 PM
