alcohol what do i need to do
Old Aug 7, 2005 | 09:39 AM
zbower7's Avatar
Default alcohol what do i need to do
alright heres my set up. i have a ls integra motor darton sleeved bored to 84mm. aries pistons 9:1 eagle rods. top end is crower regrinds for cams dual stage valve springs ferrea .5 oversived valves and bronze valve guides. ported and polished sombustion chambers exaust and intake ports. i am running a walbro 255 fuel pump with 1000cc injectors. and i have a t4 super 70 turbo. right now i am making 351 hp and 301 tourque till 6500rmp and then the tires brake loose on the dyno. thats on pump gas and 24lbs of boost. i really wanna run alcohol but would like to know what i might have to change in my setup to run strait alcohol instead of gas. please help
Old Aug 7, 2005 | 10:02 AM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Re: alcohol what do i need to do (zbower7)
Go to Drag Racing and All Motor, they will probably be more help man. Goodluck.
Old Aug 7, 2005 | 10:20 AM
Yambor's Avatar
Default Re: alcohol what do i need to do (ahrpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahrpr &raquo;</TD></TR><TR><TD CLASS="quote">Go to Drag Racing and All Motor, they will probably be more help man. Goodluck.</TD></TR></TABLE>
hondapimp125
Jan 22, 2010 06:59 PM
JDMH22Prelude
Jun 22, 2006 09:44 AM
zbower7
Aug 15, 2005 08:45 PM
9SECQTR
Aug 24, 2004 09:57 AM
