ctr piston ring question
Old Aug 6, 2005 | 11:55 PM
sir2sol's Avatar
Default ctr piston ring question
i'm trying to build a decent all motor b16a. only problem i've ran into is locating piston rings. the pistons i'm using are ctr .025 ob pistons. i've pretty much looked everywhere and found nothing short of like a couple hundred dollar piston ring sets. anyone have any ideas on where i might find these things.
also what (if any) are the differences between b18a/b rings and b18c rings, other than one's being for a vtec motor and the other for a non-vtec motor?
Old Aug 7, 2005 | 06:07 AM
NJIN BUILDR's Avatar
Default Re: ctr piston ring question (sir2sol)
Ctr,b16a b18a,b,c are all the same size ring set.Hastings 2C4666 +.025 is their part number.Nippon rings also work well.Either set is around $50-$60 plus shipping. http://www.jisengine.com/list-....html http://www.napaonline.com/cgi-...rings . The perfect circle are a good set also.
Glenn
Old Aug 15, 2005 | 01:55 PM
spoonek4's Avatar
So what I have to do is tell the parts guy i need piston rings for +.25mm overbore then?
Old Aug 15, 2005 | 08:30 PM
sir2sol's Avatar
Default Re: ctr piston ring question (spoonek4)
yeah, actually if ur not too picky about where ur rings come from, advance auto sells overbore piston rings for b series engines. only problem is they're a special order part and they'll usually take a couple of weeks to get them.
Old Aug 15, 2005 | 11:25 PM
mtber's Avatar
Do your self a favor...
Order oem .25 over rings...
Len: https://honda-tech.com/zerothread?id=977771
or
Pm bert-o
Jago
Mar 18, 2007 11:11 PM
sir2sol
Apr 29, 2005 06:14 AM
MugenB16A2
19
Nov 28, 2003 09:18 AM
vtec69
Nov 21, 2001 06:47 AM
vtec69
Nov 21, 2001 06:36 AM
