How to fix climate control knob??
Old Aug 6, 2005 | 10:30 PM
1992AccordEX's Avatar
Default How to fix climate control ****??
Ok, my fan **** has been broken a while now...i got a new ****, when i went to use it i couldnt for the life of me figure out what was wrong, then i looked at the temp **** and saw the pin or whatever u wanna call it that the **** hooks on to...
The fan side doesnt have that pin, i was wondering how i could get it fixed and where they would do something like that...thanks guys
Old Aug 6, 2005 | 11:35 PM
The_Todd's Avatar
Farts in the shower
Default Re: How to fix climate control ****?? (1992AccordEX)
Junkyard but the problem is within the design...I would honestly go to your honda dealer and pick them up as they are no more than 5 bucks a piece .
Old Aug 7, 2005 | 08:40 AM
i20ar's Avatar
Default Re: How to fix climate control ****?? (.ken)
how do you replace those pins? do they screw in?
Old Aug 7, 2005 | 10:26 AM
CB7VTEC's Avatar
There should be a shaft for both ***** to be pushed onto. If it's not there there's no doubt that it broke off and is probably attached to the old **** you may have thrown away. In any case once the shaft is broken the fan switch is useless. Go to the dealer and purchase a new fan switch.
To put it in you need to remove your stereo, center console/cupholder, cig. lighter & ashtray and the dash bezel. Removing the bezel requires you to pop out (carefully, the plastic is easily damaged) all the vents and switches to access hidden screws. Once that is off you have access to the climate control screws. from there it's pretty much self-explanitory. Screw the new switch on, plug it in, and throw it all back together.
Hope this helped
aksegura
Feb 13, 2015 01:01 AM
2005accordUF
Sep 1, 2008 06:35 AM
DA808CHOPSHOP
Mar 31, 2008 03:00 AM
dbbyleo
May 24, 2007 08:39 AM
1992AccordEX
Aug 19, 2005 10:39 AM
