A/C Issues
Old Feb 8, 2015 | 02:59 PM
aksegura's Avatar
Default A/C Issues
I accidentally broke the **** on my 95 Honda Accord's a/c and it is stuck on full heat. Is there anyway to turn it down even though its broken? My car always gets really hot even if the a/c is off because it's on full heat. Thanks in advance
Old Feb 8, 2015 | 03:02 PM
aksegura's Avatar
Default Re: A/C Issues
This is how it broke
Old Feb 8, 2015 | 03:06 PM
HonBeer's Avatar
Ghetto it with vice grips.
Old Feb 8, 2015 | 03:51 PM
rockycat's Avatar
Close the valve under the hood. It is passenger side next to the firewall.
Old Feb 8, 2015 | 05:39 PM
Fitz Williams's Avatar
10 Year Member
Pull the **** off the fan speed control and turn the temp down.
Old Feb 8, 2015 | 06:34 PM
rockycat's Avatar
The fan switch is a small slide switch and the temp control is large so no can do.
Old Feb 8, 2015 | 10:06 PM
holmesnmanny's Avatar
Old Feb 9, 2015 | 06:11 AM
10 Year Member
Both mine are the same size. Side by side. #12
Old Feb 9, 2015 | 06:22 AM
masospaghetti's Avatar
I think Dorman sells those ***** in a blister pack as a "HELP" part.
Old Feb 13, 2015 | 12:44 AM
slowcivic2k's Avatar
Source replacement parts from a junkyard. Determine the mode of failure (stupidity etc) to prevent a future failure. The heater position can be manually adjusted at the control valve on the heater core lines in the engine compartment. Since we do not know where the part failed, pulling on the cable may or may not produce a change in heat output.
Old Feb 13, 2015 | 01:01 AM
Treyschls's Avatar
Yea mine broke on me aswell.. I ended up going to the Honda Shop but I cant remember the price for one...
You can get the blend door closed by reaching down under the glove box mostly to the left side and push the lever with the cables in the opposite direction. OR go under the hood and straight down under the throttle body and push the lever on the heater hose to the closed position...
*LEFT image is under hood.
*RIGHT image is under glove box.
95WhiteTeg
Sep 2, 2011 05:55 PM
Natural Aspirations
Engine Management and Tuning
18
Mar 1, 2011 12:48 PM
snzh22
Jun 26, 2007 04:18 PM
blackpearlv6
May 6, 2006 12:49 AM
1992AccordEX
Aug 7, 2005 10:26 AM
