timing belt came off what to do?
Old Aug 6, 2005 | 09:14 PM
kaoss_11's Avatar
B A N N E D
Default timing belt came off what to do?
Driving from work today normal out of vtec when my whole car loses power and right away i turned the car off because i knew what it was.
Old Aug 6, 2005 | 09:59 PM
hatchi's Avatar
Default Re: timing belt came off what to do? (kaoss_11)
if you didnt hear valves hitting pistons just slap on a new timing belt and water pump and you should be fine
Old Aug 6, 2005 | 10:12 PM
kaoss_11's Avatar
B A N N E D
yeah i didnt hear **** as soon as it happened i shut the car car off and didnt attempt to turn it back on
Old Aug 8, 2005 | 09:27 PM
transitions's Avatar
you gotta replace the water pump also if you blow your timing belt?
Old Aug 8, 2005 | 09:34 PM
RangerDan's Avatar
Default Re: (pr3lud3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3lud3 &raquo;</TD></TR><TR><TD CLASS="quote">you gotta replace the water pump also if you blow your timing belt?</TD></TR></TABLE>
Uhm..no but you might as well cause theres no better time to do it.
Cross your fingers on that valvetrain.
Old Aug 8, 2005 | 09:38 PM
94_HATCH's Avatar
Just put a new timing belt on an cross your fingers. My brother broke his timing belt while driving home. We just lined everything up and installed new belt. Started right up
Old Aug 9, 2005 | 04:03 AM
kaoss_11's Avatar
B A N N E D
checked and my motor is still good
Old Aug 9, 2005 | 01:55 PM
transpar_nt's Avatar
Default Re: timing belt came off what to do? (94_HATCH)
My mom's timing belt broke while she was at a stop sign. She had no idea what happened, but told me all about it when I got back from college. "The mechanic said I was really lucky. I don't know why, but apparently there can be alot of damage when the, uh, something belt breaks. Would that be the alternator belt?" "No, it wasn't mom. Don't worry about it."
vtek9
Sep 2, 2007 09:55 PM
faSHOwidIT
Feb 25, 2006 03:00 AM
Iomega01
Aug 2, 2005 08:12 PM
2camsaam
Jul 30, 2003 12:20 PM
1hotintegra
Jun 16, 2003 03:10 PM
