Engine Noise - Flapping Sound?! WTF Mate?!
Old Aug 6, 2005 | 09:08 PM
dr_latino999's Avatar
Default Engine Noise - Flapping Sound?! WTF Mate?!
Ok, cliffnotes -
D16Z6, engine is making a wierd noise when the throttle is depressed from 2800RPM on, but this noise goes away when the throttle is released. It sounds as if something is flapping real hard against something else, what you would expect to hear from a piece of paper inserted into a desk fan. Isn't the timing belt, we checked, not the alternator belt.
Possible Ideas
1) Loose Valve
2) LMA's? Do SOHC even have those?
3) Actually something around the timing belt in the cover
4) ...........................Bearing?!
Any ideas, inputs will be welcome. I will be waiting till about 4:00am before I hit the motor to give it adequate time to cool down.
Old Aug 6, 2005 | 10:03 PM
firealhrdcor's Avatar
any chance it could be an exhaust leak? sometimes those sound ridiculous depending on where they are and the vehicle.
is it more constant or spiratic?
Old Aug 7, 2005 | 07:15 AM
Default Re: (firealhrdcor)
Ok, it is the morning and I have checked the following -
Valve Lash - OK
Timing Belt - OK
Rod Knock - Spark Plug Test - OK
The noise is still there and coming from the area of the flywheel clutch. Could one of the bolt have come loose causing excess chatter when it is engaged?
Old Aug 7, 2005 | 10:46 AM
Sobe_Death's Avatar
maybe one of the springs from the clutch disk.
Old Aug 7, 2005 | 11:12 AM
Default Re: (Sobe_Death)
Could be, I am going to look into the distributor now as the car cut out on me while it was running in the garage earlier and I am no longer getting spark.
Old Aug 7, 2005 | 11:37 AM
vtecn8ive's Avatar
Default Re: (dr_latino999)
perhaps screw in the dizzy came off .
also on my last dizzy cap it was kinda loud but now it sounds fine. have you changed it all (Recently)?
have you checked your fans out? lol I know but didn't see it listed.
-Shane
Old Aug 7, 2005 | 11:41 AM
Default Re: (vtecn8ive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">perhaps screw in the dizzy came off .
-Shane</TD></TR></TABLE> I am feeling for the rotor possibly, but if the bearing inside died I have a spare B7 I can use temporarily (I hate ghetto rigging). I have not changed any of the distributor parts as I have only had the motor running for 6 days. My fan is not the source of the noise, lol, if it made noise every know and then I would feel more comfortable in the fact that it is coming on.
Old Aug 7, 2005 | 11:55 AM
sanimalp's Avatar
$cat /dev/urandom
yeah check out your radiator fan there might be junk up in it or something.
Old Aug 7, 2005 | 12:07 PM
Default Re: (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">yeah check out your radiator fan there might be junk up in it or something.</TD></TR></TABLE> It is not the radiator fan, why do I know this, because the sound is RPM related. If this was an older RWD car with the fan driven off the motor I could see this as a possibility. But the fan on a Civic is an electronically triggered device that only turns on at certain temperatures. I could get the engine to make noise as soon as I turned it on and revved it after sitting dormant for 6 hours.
Old Aug 7, 2005 | 12:09 PM
vtecn8ive's Avatar
what about A/C fan j/p.
Yeah check out the dizzy. Otherwise it could be in the clutch setup but I would check the dizzy first.
-shane
Old Aug 7, 2005 | 12:31 PM
I went for the distributor and find the following -
Remove cap, rotor intact but oil has pooled in the bottom of the cap (part closest to transmission)
The black cover that goes underneath the cap and covers the coil and the ignitor is loose which could explain the WHAPWHAPWHAP noise due to harmonic vibrations etc.
The ignitor is covered in oil, the innards all have a light covering of oil.
Bad seal in the distributor? If so, is the distributor junk or can this seal leaking oil be scavenged from another distributor?
Old Aug 7, 2005 | 01:00 PM
vtecn8ive's Avatar
I would say yes but you will probably have to take it all apart. EVERYTHING. just mark it and pull of the dizzy to make sure that its just the seal.
I would take everything apart and clean it up real nice. Not sure what to use something non-flammable, and that doesn't leave a residue.
-shane
Old Aug 7, 2005 | 04:24 PM
sanimalp's Avatar
$cat /dev/urandom
they make spray electronic parts cleaner. that would be the best stuff, cause its non conducting and still removes oil and grease.
Old Aug 7, 2005 | 04:42 PM
After disassembly and cleaning, I chose to purchase a new distributor. A key factor in my decision was that the input shaft was not only wobbly, could be spun in an ellipse rather then a tight circle.
Old Aug 7, 2005 | 07:26 PM
vtecn8ive's Avatar
good choice its what I would have done.
Old Aug 7, 2005 | 07:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">good choice its what I would have done. </TD></TR></TABLE> I have also come to a startling discovery, when you use an A6/B7 distributor on the Z6 head you have to modify the legs to fit. Well, why not just switch the little tower where the top most bolt mounts? I am talking the piece held on with two bolts and the valve cover holds part of it down.
Old Aug 7, 2005 | 08:39 PM
vtecn8ive's Avatar
haha damn it now I will have to go look at my z6 head where I have my dizzy hooked up to with its modified legs!!!
Old Aug 8, 2005 | 04:31 AM
I am going to try and switch them today, if it works, yay for the modified leg people, if not, no harm no foul.
Old Aug 8, 2005 | 06:20 AM
vtecn8ive's Avatar
lol, let me know.. uh I mean us
Old Aug 8, 2005 | 10:26 AM
And the answer is....no it won't work.
Old Aug 11, 2005 | 01:25 PM
Ok, it is not the distributor making the noise, I have canceled that out, any other ideas ladies and gents?
Old Aug 11, 2005 | 04:16 PM
ImportHatch's Avatar
Does it make the sound while revving in neutral or does it have to have a load on it?
Yager-
Old Aug 11, 2005 | 04:43 PM
Default Re: (ImportHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportHatch &raquo;</TD></TR><TR><TD CLASS="quote">Does it make the sound while revving in neutral or does it have to have a load on it?
Yager-</TD></TR></TABLE> Neutral - Quick chatter at 2800 RPM, fades into background
In Gear - Chatter at 2800RPM onward, I am thinking loose pressure plate, clutch assembly. Is that possible?
Old Aug 11, 2005 | 06:49 PM
Update - Drove around some more, noise was apparent from idle onward, when car was decelerating it would be there and when car was idling it made the most dreadful knocking noise. Drove home in 5th, immediatly got car in air and on jackstands and drained the oil. Oil came out nice and thin, slight darkness to the color (less then 600 miles). I had placed three magnets in my catch tray, let it sit for five minutes, then let the oil drain into the bottom of the catch; magnets came back empty so I don't know what the hell to expect when I pull the oil pan off tomorrow.
Old Aug 13, 2005 | 09:10 AM
It's official, I spun a bearing, I have the oil pan off and there is a copper mine at the bottom....damn it!!!!!! Pictures to be added later.
willfly
Apr 1, 2013 08:02 AM
dmanfree
Mar 15, 2013 11:19 AM
zxracer3
Jul 1, 2007 01:20 PM
jmpgraphy
Aug 1, 2006 02:29 PM
dr_latino999
Aug 7, 2005 12:32 PM
