Engine Noise - Flapping Sound?! WTF Mate?!
Old Aug 6, 2005 | 09:08 PM
dr_latino999's Avatar
Default Engine Noise - Flapping Sound?! WTF Mate?!
Ok, cliffnotes -
D16Z6, engine is making a wierd noise when the throttle is depressed from 2800RPM on, but this noise goes away when the throttle is released. It sounds as if something is flapping real hard against something else, what you would expect to hear from a piece of paper inserted into a desk fan. Isn't the timing belt, we checked, not the alternator belt.
Possible Ideas
1) Loose Valve
2) LMA's? Do SOHC even have those?
3) Actually something around the timing belt in the cover
4) ...........................Bearing?!
Any ideas, inputs will be welcome. I will be waiting till about 4:00am before I hit the motor to give it adequate time to cool down.
Old Aug 6, 2005 | 09:15 PM
1slowhatchie's Avatar
Default Re: Engine Noise - Flapping Sound?! WTF Mate?! (dr_latino999)
sounds like a you blew your motor up.(i think it's your rod)
Old Aug 6, 2005 | 09:18 PM
1995Ex_Sedan's Avatar
Rod knock or the lifters tapping.
Old Aug 6, 2005 | 09:23 PM
Default Re: Engine Noise - Flapping Sound?! WTF Mate?! (1slowhatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowhatchie &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a you blew your motor up.(i think it's your rod)</TD></TR></TABLE> I would hope not without further indication, I will drain the oil and look for shavings.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan &raquo;</TD></TR><TR><TD CLASS="quote">Rod knock or the lifters tapping.</TD></TR></TABLE> I am hoping for lifters; would rod knock only occur on acceleration of the motor and not in decel?
Old Aug 7, 2005 | 07:15 AM
Ok, it is the morning and I have checked the following -
Valve Lash - OK
Timing Belt - OK
Rod Knock - Spark Plug Test - OK
The noise is still there and coming from the area of the flywheel clutch. Could one of the bolt have come loose causing excess chatter when it is engaged?
Old Aug 7, 2005 | 11:12 AM
I am going to look into the distributor now as the car cut out on me while it was running in the garage earlier and I am no longer getting spark.
Old Aug 7, 2005 | 12:32 PM
I went for the distributor and find the following -
Remove cap, rotor intact but oil has pooled in the bottom of the cap (part closest to transmission)
The black cover that goes underneath the cap and covers the coil and the ignitor is loose which could explain the WHAPWHAPWHAP noise due to harmonic vibrations etc.
The ignitor is covered in oil, the innards all have a light covering of oil.
Bad seal in the distributor? If so, is the distributor junk or can this seal leaking oil be scavenged from another distributor?
mreed
Jan 16, 2023 09:02 PM
ZurEnArrh
Jan 11, 2018 11:07 AM
Peasonrice
Nov 3, 2005 11:13 AM
dr_latino999
24
Aug 13, 2005 09:10 AM
SoupBA
Sep 11, 2004 04:39 PM
