Hollowed Out my Cat and now my exhaust sounds like crap
Old Aug 6, 2005 | 08:12 PM
4.6LJeepXJ's Avatar
Default Hollowed Out my Cat and now my exhaust sounds like crap
I hollowed out my cat. and since then i have heard a tingy rattle from underneath my car. Only under moderate to heavy accelteration...Cold Start especially, around 2,500-4,000 RPM. I do have a small upper end noise from somewhat loose valve lash. I have banged on every heat shield and removed anything that seemed to be loose. Has anyone else ever experienced this after punching out a cat. Also I removed both upper and lower heatshields that are attached to the cat itself. P.S. Anyone want to sell an O2 sim for a 96 Prelude... If not Ill search it no stress... dont feel like being yelled at on honda tech for not searching....
Old Aug 6, 2005 | 08:44 PM
The Phil's Avatar
Default Re: Hollowed Out my Cat and now my exhaust sounds like crap (4.6LJeepXJ)
What were you thinking? Of course it sounds like crap. You hollowed your cat out.
Old Aug 6, 2005 | 08:54 PM
Jordans95si's Avatar
i have that sound at exactly 2500 rpms, im trying to get it out , it sounds like it might be coming from around the cat, idk im working on it tom, i just installed it yesterday
Old Aug 7, 2005 | 06:17 AM
scrubachu's Avatar
Default Re: (Jordans95si)
ive had mine hollowed out since it was garbaged anyways when i put my cat back on. its never sounded like crap ever, and i dont have any rattling anywhere. i took all the heatshiled off the cat also. theres gotta be something rubbing somewhere, or maybe you didnt get everything out of the cat. the honeycomb in mine was garbage, and had broken apart and gotten in my old exhaust, which is why i just cleared out the whole cat.
Old Aug 7, 2005 | 08:50 AM
Pullig's Avatar
Default Re: (scrubachu)
i hollowed mine out also and mine still had the stock resonator and a straight thru muffler and it sounded weird like a raspy air sound going through the exhaust. So i got a guy to cut out the resonator and put in a pipe. problem solved. it is very loud now.
Old Aug 7, 2005 | 09:39 AM
john d
Guest
Posts: n/a
Default Re: (Pullig)
i can sell you the pipe that you need
check the link in my sig
Old Aug 7, 2005 | 04:33 PM
Eddiebx's Avatar
hollowed out cats/ straight pipes/ tests pipes, all sound like **** compared to a car with a cat, period.
if yours doesnt sound like ****, you have low standards on what sounds like ****
Old Aug 7, 2005 | 05:13 PM
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">hollowed out cats/ straight pipes/ tests pipes, all sound like **** compared to a car with a cat, period.
if yours doesnt sound like ****, you have low standards on what sounds like ****</TD></TR></TABLE>
def agreed...dont get all ricey...keep it clean
Old Aug 7, 2005 | 05:58 PM
T-King's Avatar
Yep put a test pipe on my car, with 2.5 pipping and thermal R&D muffler and it would ring and was so loud so it was kinda imbarassing. Put a resignator on it and it sounds great, real deep and it still flows very well also.
Old Aug 7, 2005 | 06:34 PM
dohcvtecpower's Avatar
Default Re: (T-King)
i think i am the onmly one that likes the sound of 2.5 in custom piping wit a test pipe
Old Aug 7, 2005 | 07:06 PM
GaRn's Avatar
It's because you are missing a crucial device, its called a turbocharger..
Old Aug 7, 2005 | 09:47 PM
OEM_ASSASSIN's Avatar
should have bought a hi flow. My friend punched out the cat on his civic and it sounds like the wrath of god. It hurts...
Old Aug 7, 2005 | 10:15 PM
Eddiebx's Avatar
Default Re: (GaRn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">It's because you are missing a crucial device, its called a turbocharger..
thats only cuz that pesky turbo spoooling up covers the noise
Old Aug 7, 2005 | 10:54 PM
98TypeSH's Avatar
i had catless system on my JUN head. I also had a monster 20" resonator to take care of the fart cannon APC noise. Throw a resonator on that thing or a new cat. For the minimal gains you get from removing/gutting a cat, its pointless to be a mass polluter.
JDMEK9R
Jan 9, 2008 10:58 AM
Feelseg
12
Apr 18, 2006 05:14 PM
Token Blk Guy
Sep 14, 2002 10:46 AM
onyx00
Mar 5, 2002 03:19 PM
JoshRambo
Oct 1, 2001 02:31 PM
