Garrett T3 Turbo
I have a .42.48 Turbo That someone changed the exhuast housing on to a .63.. So that make it a .42.63... do you guys think that there could be a problem with it? Its going onto a B18b1 motor... IT has no shaft play and spins freely
Na the 63 hot side housing is a pretty regular hot side for a B-series.. You can change the Cm. its ok....Now the little T3 is kinda small turbo dont you think ? .42 trim
Save up for a bigger set up, youll be happy.
They aren't the most monsterous turbos out there but they get the job done. My lil 2.5L SOHC dodge engine throws down 266FWHP at 16psi with a stock 50trim t3 .42/.48 and it hits full boost at 2200RPM. Not super impressive compared to whats on this board, but not bad for a $3k investment (bumper to bumper).
