clutch/flywheel tranny first impressions
Old Feb 20, 2002 | 09:44 PM
MrSmith's Avatar
Default clutch/flywheel tranny first impressions
Got my car back today with my new toda fly exedy clutch and si tranny. Clucth engagement is low and smooth, rev build and drop very quickly. I had to learn to upshift giving it gas quicker because the rpms would drop too low in between shifts. One weird thing, I feel like i have a shirt shifter now. The gears seem to be spaced slightly closer and the throws are shorter then with the gsr tranny. RPMs are right where they are suppoused to be, 5th gear 40mph 2200 instead of 2000. I'm not going to rev it higher than 3k until everything is properly broken in. 49 miles so far only 451 to go My mech also inspected my act that was in there, 4 months and about 10k miles of use. The throwout bearing was pretty much shot according to him, "dried up" was the expression he used? Pressure plate was fine, the disc showed signs of wear but was in ok condition. Probably would have lasted a while still. The bearing definately needed to be replaced. Oh well now i have a backup clutch. One more thing, I also had him do a compression test, between 185 and 190 on all 4cylinders. I was pretty happy with that considering it has a little over 100k miles. Thats about it, sorry for the long post
Old Feb 20, 2002 | 09:52 PM
fluke702's Avatar
Default Re: clutch/flywheel tranny first impressions (MrSmith)
So is the si tranny better than a teg's tranny? Why?
Johnny Gasparini's Avatar
I didn't ask for a dime.
As far as the Si tranny is concerned, it does have a shorter throw much like the ITR tranny.
Old Feb 20, 2002 | 10:00 PM
MrSmith's Avatar
Default Re: clutch/flywheel tranny first impressions (JSM)
The Si tranny (SC4) has shorter ratios ala Type R. I didnt know that the throws would be shorter. Interesting.
Old Feb 20, 2002 | 10:03 PM
There you go. Thats what I meant to say. The shorter ratios.
Old Feb 20, 2002 | 11:59 PM
threatcon13's Avatar
New User
is the exedy ceremetallic or ogranic
Old Feb 21, 2002 | 05:04 AM
MrSmith's Avatar
Default Re: clutch/flywheel tranny first impressions (Titus333)
its the exedy organic the bearing was the one that came with the act, I was using their heavy duty pressure plate with organic disc.
Old Feb 21, 2002 | 10:05 AM
maggsgsr's Avatar
Are the gears shorter and the throws or just the throws?And wich shifter feels better?
Old Feb 21, 2002 | 10:19 AM
hybrider's Avatar
Default Re: clutch/flywheel tranny first impressions (maggsgsr)
Old Feb 21, 2002 | 02:17 PM
eh-D's Avatar
Default Re: clutch/flywheel tranny first impressions (hybrider93)
I'm thinking the reason you are feeling shorter throws is becuase the linkage is properly adjusted. I'm almost sure there isn't any reason that the distance the shifter moves between gears would be different.
95dc2teg
Transmission & Drivetrain
Sep 14, 2009 03:23 AM
twinj
Apr 20, 2007 09:31 PM
90LSpimpin
11
Sep 19, 2004 10:13 AM
90LSpimpin
Sep 19, 2004 12:58 AM
HX_Guy
Aug 29, 2001 09:09 AM
