header paint
Old Aug 6, 2005 | 04:22 PM
jacobforcecrx's Avatar
Default header paint
I bought a dc sports 4-1 header. has a little bit of rust. after i sand a little should i spray a coat of primer or just hit with high temp paint. thanks
Old Aug 6, 2005 | 04:33 PM
D Grade's Avatar
Default Re: header paint (jacobforcecrx)
Neither, get it ceramic coated professionally. The ceramic coating will lower heat emissions from the header and actually hold up over time to the heat. You can get ceramic coat in various colors such as grey, flat black, even a polished look.
It'll actually serve a purpose on top of looking good.
Old Aug 6, 2005 | 04:36 PM
Default Re: header paint (Dieselboys MK3)
what is the price range. Tight on money, but if not to expensive will consider.
Old Aug 6, 2005 | 04:37 PM
anyone else.
EL Vap133's Avatar
The paint will just start to bubble once the header gets hot.
Old Aug 6, 2005 | 04:56 PM
HamiltonRex's Avatar
Default Re: header paint (EL Vap133)
VHT Fireproof paint works.
-Eric
Old Aug 6, 2005 | 07:32 PM
Default Re: header paint (HamiltonRex)
can i buy the paint at the local body shop or at something like walmart or something.
Old Aug 7, 2005 | 04:17 AM
tommycrx's Avatar
The professional coating is around $200; I had my header and downpipe done by HP Coatings. They cleaned up the header perfectly before coating; has held up great.
But, I understand the $$ issue; VHT will work fine, though I'd watch for rust to rear its ugly head again next spring. Coating would make sure that this wouldn't happen.
Old Aug 7, 2005 | 04:47 AM
Sifu's Avatar
Just pick the correct paint and paint it, dont think you need primer, most will bubble with heat over time so choose carefully.
If you're worried about rust then I would be carefully scraping that too, would peel any coating of it over time.
Old Aug 7, 2005 | 05:06 AM
Sikocivic's Avatar
Default Re: (Sifu)
I bought some paint at a store that sells wood stoves and fireplaces. I used it to paint my turbo manifold and its held up for 2 1/2 years. You will have to make sure you get ALL the old paint off before you repaint it. I sandblasted my manifold and then painted it. Still looks good
Old Aug 10, 2005 | 03:46 AM
D Grade's Avatar
Default Re: (Sikocivic)
I can get coating done locally for around $100 for a header/exhaust mani in either flat black (2300F resistant), or a polished like finish (1800F resistant).
Old Aug 10, 2005 | 06:48 AM
Newark Built's Avatar
* B A N N E D *
Default Re: (Dieselboys MK3)
Sandblast the header b4 you paint it...
Most bodyshops or machine shops have them
Old Aug 10, 2005 | 06:53 AM
MattP's Avatar
Default Re: (Newark Built Kandy SiC-RX)
One option is POR-20. It's a heat resistant paint that POR15 makes. Goes on easy on sandblasted metal, looks nice. Bakes on when the metal heats up.
Old Aug 10, 2005 | 08:21 AM
Mr.Death's Avatar
I painted my DC header with high temp ceramic paint and it burned off the header as soon as I started the car. Not worth it IMO.
Old Aug 12, 2005 | 04:36 AM
* B A N N E D *
Default Re: (Mr.Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">I painted my DC header with high temp ceramic paint and it burned off the header as soon as I started the car. Not worth it IMO.</TD></TR></TABLE>
lol
That had to suck to see the work you put into painting it go down the crapper in a matter of minutes...live and learn
b18c1hatch1992
37
Apr 10, 2010 11:06 AM
lando griffin
Apr 13, 2009 09:16 AM
Aarron_M
Jul 31, 2007 08:29 AM
JDMlyfestyle
Jul 20, 2004 02:30 PM
R Legend
Dec 30, 2003 05:32 PM
