Antenna Block Off Plate
Old Aug 6, 2005 | 01:07 PM
BLUE EH3's Avatar
Help we my pennies
Default Antenna Block Off Plate
whats the purpose of this? how do u listen to the radio?
Old Aug 6, 2005 | 01:08 PM
pdiggitydogg's Avatar
Its for the civics that didnt have a radio stock.
I dont listen to the radio, so I have one - but when I do listen to it, I get my FM stations just fine.
Old Aug 6, 2005 | 01:09 PM
-Gambit-'s Avatar
Default Re: Antenna Block Off Plate (BLUE EH3)
purpose just for looks, you can still listen to the radio you just push the antenna down under the block off place
Old Aug 6, 2005 | 01:21 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Antenna Block Off Plate (-Gambit-)
i there any aftermarket antenna, like the shaark fin on a bmw?
Old Aug 6, 2005 | 01:23 PM
any antenna will work the same as stock, yes...
Old Aug 6, 2005 | 01:32 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (pdiggitydogg)
but does it have to be wired up or ...
Old Aug 6, 2005 | 01:35 PM
Um, yeah...it has to be connected to your antenna plug or it wont work...
Old Aug 9, 2005 | 06:46 PM
JokerTypeR's Avatar
I drive an EF, but I'm looking for some sort of mod as well as I hate the shirt-hanger that sticks out of my roof...
Some things I looked at was taking the 2004-5 3dr hatch's antenna and wiring that in, but it seems like i would need some sort of an adapter...?
Also, I checked the window-antenna from a 2000 Accord. Is this a good idea? Anyone with experience?
My advice on the shark fin, though...originally I hunted down the idea, but thought about something. Shouldn't a honda stay a honda?
Old Aug 10, 2005 | 01:08 PM
jsucci's Avatar
Default Re: (JokerTypeR)
i have an antena on my boat the just mounts with double stick tape to the inside of the boat, you could use this and mount it in the fender or bumper.
Old Aug 10, 2005 | 01:09 PM
northkai3's Avatar
Default Re: (jsucci)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsucci &raquo;</TD></TR><TR><TD CLASS="quote">i have an antena on my boat the just mounts with double stick tape to the inside of the boat, you could use this and mount it in the fender or bumper.</TD></TR></TABLE>
or u could put in the window where it is meant to go and will work best
Old Aug 10, 2005 | 04:27 PM
JokerTypeR's Avatar
Default Re: (northkai3)
I was kinda thinking the fender would be bad, why not just do it in the window? I'll probably go for that then throw window tint over it...
Any idea for sources?
Old Aug 10, 2005 | 05:09 PM
graveltravel's Avatar
when i bought my block off plate, i tried to pull out my oem antenna. well, it broke. so , i ordered another oem antenna. i have my oem anetnna hidden underneath the 2 middle vents in my ej1. i pick up all my stations like normal. and remember , if u use my idea, you need to cover all metal stuff with plastic or tape. it will keep engine noise down and other noises.
Old Aug 10, 2005 | 05:12 PM
smokee's Avatar
link for block off plate? i want one as my antenna is all bent and crappy looking
Old Aug 10, 2005 | 05:17 PM
your dealership
Old Aug 10, 2005 | 05:21 PM
smokee's Avatar
ah, thought it was an aftermarket peice, just skimmed the thread.
thanks
Old Aug 10, 2005 | 06:04 PM
madcrossover's Avatar
Default Re:
Autoloc makes a hidden antenna, it would be good if you want the block off plate.
I have one on my car, but I get really crappy reception no matter what in my town.
I just ran it to my radio and ran the ground to a good spot. It sticks really good on the windshield, its pretty strong.
http://www.autoloc.com/detail.lasso?itemid=hab
Old Aug 10, 2005 | 06:06 PM
chad's Avatar
Moderator
it's majic
some cars didn't come with radios so therefore no antenna was installed....thus reason for block plate at radio and antenna
Old Aug 10, 2005 | 06:10 PM
blaster834's Avatar
basicly i got it cause i was sick of peeps pulling my antenna out all the time.
Old Aug 10, 2005 | 06:12 PM
A-busive's Avatar
Default Re: (blaster834)
where can you get these block off plates from?
Old Aug 10, 2005 | 06:23 PM
GBRacing's Avatar
http://www.jhpusa.com has them for 5 bucks.
Old Aug 10, 2005 | 06:27 PM
chad's Avatar
Moderator
Default Re: (ITACRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITACRX &raquo;</TD></TR><TR><TD CLASS="quote">http://www.jhpusa.com has them for 5 bucks.</TD></TR></TABLE>
or honda
Old Aug 11, 2005 | 03:45 AM
JokerTypeR's Avatar
Default Re: (chad)
I'm just going the cheap way...
Great Stuff followed by bondo for a look of it never existing there...
Followed by the 04 civic SI stub in the back.
Unless I find the accord window antenna really sexy, but I like the stub more.
Old Aug 11, 2005 | 09:45 AM
awwsnap's Avatar
Does the antenna block off plate for the 92-95 civic also work on the 96?
Old Aug 11, 2005 | 01:45 PM
i believe it does.
you can get it at your local honda dealership for less than 4.00
thats where i got mine.
EJ8freek
36
Jan 28, 2008 02:44 PM
x_tc-Dae
Honda Fit
Dec 29, 2006 11:37 AM
2Point2EH2
Jun 21, 2006 06:18 PM
rasinhell
Aug 4, 2005 12:11 PM
mattL
Nov 5, 2002 02:53 PM
