Anyone have a mini mill or have opinions on them ?
Old Aug 6, 2005 | 10:16 AM
RCautoworks's Avatar
Default Anyone have a mini mill or have opinions on them ?
Just curious if anyone has one, did a search and really did not find any threads. I found a couple for under $500 , but not sure how good they are. So does anyone have any recommendations ? Or does anyone have pics of pieces they cut themselves on a mini mill ?
Just noticed, the ones I looked at seemed to be Harbor freight brands, or equal to them.
Here are the specs for the Grizzly mill:
Spindle Taper: MT #3
Head Travel: 9-7/8"
Head Tilt: 45 degrees L/R
Max. distance spindle to table: 11-1/2"
Swing: 12-3/4"
Longitudinal Travel: 9-1/4"
Cross-slide travel: 4"
Table size: 3-5/8" x 15-3/4"
Speeds: Variable
Speed Range: 0-2500 RPM
Motor Size: 3/4 HP
Shipping Weight: 153 lbs.
Old Aug 6, 2005 | 10:25 AM
beepy's Avatar
Default Re: Anyone have a mini mill or have opinions on them ? (90blackcrx)
I would like to have one. I wonder where you would find good bits in Morse taper #3?
Old Aug 6, 2005 | 10:37 AM
Default Re: Anyone have a mini mill or have opinions on them ? (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">I would like to have one. I wonder where you would find good bits in Morse taper #3?</TD></TR></TABLE>
I'm sure you can find them some where
Old Aug 6, 2005 | 11:33 AM
ExploitedRacing-HR's Avatar
Those things are junk... they chatter to much.
Old Aug 6, 2005 | 12:09 PM
beepy's Avatar
Default Re: (ExploitedRacing)
I'm sure they would chatter like hell if you are trying to plow through metal like with a full sized mill. Probably OK if you take 0.005 a pass.
Old Aug 6, 2005 | 12:48 PM
Default Re: (beepy)
I think this might turn into a harbor freight bandsaw debate, some like the bandsaw, and some don't
Old Aug 6, 2005 | 12:58 PM
.005" is hardly anything.
Old Aug 6, 2005 | 12:59 PM
I guess before anything i should acually ask what the mill will be used to do.
Old Aug 6, 2005 | 01:17 PM
david@didrace.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExploitedRacing &raquo;</TD></TR><TR><TD CLASS="quote">.005" is hardly anything. </TD></TR></TABLE>
Old Aug 6, 2005 | 02:13 PM
beepy's Avatar
Default Re: (backpurge)
Yeah, 0.005 is hardly anything but it is enough to resurface a flange in two or three passes.
Oh, I get it... Was the original poster planning on making flanges with that little thing? Yeah, I agree this machine would suck for major work like that. But for resurfacing, precision drilling, and simple operations like that I don't see a problem.
Old Aug 6, 2005 | 06:04 PM
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, 0.005 is hardly anything but it is enough to resurface a flange in two or three passes.
Oh, I get it... Was the original poster planning on making flanges with that little thing? Yeah, I agree this machine would suck for major work like that. But for resurfacing, precision drilling, and simple operations like that I don't see a problem.</TD></TR></TABLE>
Actually I'm not looking to make flanges, making guns actually and other things.
Old Aug 7, 2005 | 11:46 PM
rjardy's Avatar
I am a bit of a garage gunsmith. That said, I own a Grizley mini mill, and fun gunsmithing, its great. I could not imagin not having it. The last project I completed, was a 1911. PM me if you want some pics.
Old Aug 8, 2005 | 08:00 AM
Keyhole's Avatar
Default Re: (rjardy)
I don't have any experience with a mini mill myself, but the people I've talked to say that it's great for light work. The only people that seem to have a problem with them have access to their own full size mills
There are quite a few companies that make them. I'd suggest getting one with an R-8 taper as there is much more used tooling available.
Check out http://www.mini-lathe.com/Mini...l.htm for good information and reviews.
Also the learning center on http://www.littlemachineshop.com is a great resource.
Old Aug 8, 2005 | 08:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">I am a bit of a garage gunsmith. That said, I own a Grizley mini mill, and fun gunsmithing, its great. I could not imagin not having it. The last project I completed, was a 1911. PM me if you want some pics.</TD></TR></TABLE>
That's good to know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keyhole &raquo;</TD></TR><TR><TD CLASS="quote">I don't have any experience with a mini mill myself, but the people I've talked to say that it's great for light work. The only people that seem to have a problem with them have access to their own full size mills
Also the learning center on http://www.littlemachineshop.com is a great resource.</TD></TR></TABLE>
I had the first link, the second I did not. Thank you, great charts on that site. Looking at the harbor freight one right now, plus I have a coupon so it would be even cheaper then the advertised price.
Anything else I should look out for ?
Old Aug 8, 2005 | 09:40 AM
Mightyt11's Avatar
Default Re: (90blackcrx)
http://www.mscindustrial.com
And whats the difference between the #3 Morse and the R8 Taper?
Old Aug 8, 2005 | 11:19 AM
Default Re: (Mightyt11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mightyt11 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.mscindustrial.com
And whats the difference between the #3 Morse and the R8 Taper? </TD></TR></TABLE>
Also curious about that.
Old Aug 8, 2005 | 11:44 AM
Keyhole's Avatar
R8 Taper is standard on Bridgeport and other large mills. Since thats the case, there is more used and affordable tooling available.
I'm not sure where #3 Morse comes from, but used tooling is scarce.
Old Aug 8, 2005 | 10:37 PM
rjardy's Avatar
Default Re: (Keyhole)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keyhole &raquo;</TD></TR><TR><TD CLASS="quote">R8 Taper is standard on Bridgeport and other large mills. Since thats the case, there is more used and affordable tooling available.
I'm not sure where #3 Morse comes from, but used tooling is scarce.</TD></TR></TABLE>
Morse # 3 is smaller that R8 and is generally used in smaller machines. Or in my case, the tail stock of my lathe is cut for a MT#3
Rob
Modified by rjardy at 2:18 AM 8/14/2005
rjardy's Avatar
both sizes of collets are easily atainable.
Rob
Old Aug 9, 2005 | 11:31 AM
legendboy's Avatar
it wouldn't work for resurfacing flanges. even larger drill/mill type machines don't work very well.
it would be alright for hobby type stuff like rc parts ...etc..
Old Aug 9, 2005 | 01:15 PM
rjardy's Avatar
Default Re: (legendboy)
A full sized mill should not have any issues planning a surface of a flange.
Rob
Old Aug 9, 2005 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">it wouldn't work for resurfacing flanges. even larger drill/mill type machines don't work very well.
it would be alright for hobby type stuff like rc parts ...etc..</TD></TR></TABLE>
Why though ?
Old Aug 9, 2005 | 04:45 PM
kb58's Avatar
Banned
A good mill needs stiffness. There's no way to get that stiffness without the bulk of a full size machine. A large machine doesn't guarantee good success, but it's a good start. It takes about $1500 before you begin to get into the good ones. Like other said, it's all be degree about what you need for a given job. Doing little stuff in brass? Any machine will do that fine. But doing large hard material requires a very stiff machine. I'd recommend something like this with a 6" x 26" table.
There's a Yahoo group just for this: http://groups.yahoo.com/group/6x26millingmachines/
Old Aug 10, 2005 | 09:24 PM
88gts's Avatar
Default Re: (kb58)
The accuracy of a machined part is only as good as the rigidity of the setup. Most of the larger mills weigh 500+ pounds. The mini mills like you have here can be made abit more solid by filling the tube solid with cement but it makes it that much heavier. These things are really meant to be set in place and left there. They are a bitch to move from place to place unless you have a forklift avaialble.
The taper that people are speaking of for those that dont know is the inside of the spindle. There are specific types of tapers. I think these guys said r8 is common so you can type in r8 on google and find what you need tooling wise. There are adaptors for the #3 but they are a pita IMO&gt;.
I like that mill in the yahoo groups pic. I hate yahoo groups. The mill in the pic is cool it actually has a knee to it .
I think a standard econo bridgeport style/size mill starts around $3k from most industrial supply houses. They are big and burly as mentioned above.
I cant see where one of these machines that has been trammed in could not surface a manifold flange. I guess if it wasnt trammed in then you could do it huh? This assuming you can adjust the angle of the head and all that. If its a fixed head then you are right you prolly cannot surface a manifold.
SHystrdyGSRtdy
Honda Motorcycles
25
Sep 27, 2006 09:32 PM
mike93eh
11
Sep 4, 2005 10:32 PM
babietuan323
Jan 4, 2005 05:13 AM
Turbocivic94
Jun 8, 2004 04:36 PM
Tinker219
Feb 25, 2004 08:28 AM
