RPM's in 5th gear at 80 mph
Old Aug 6, 2005 | 09:48 AM
Jay Blazed's Avatar
Default RPM's in 5th gear at 80 mph
So whats everyone's #s
tring to get a good idea for a tranny swap in my ls
what do you need to cruise at 80 mph with the rpms around 3500
Old Aug 7, 2005 | 04:46 PM
Jay Blazed's Avatar
Bump
Old Aug 7, 2005 | 04:49 PM
teler86's Avatar
Default Re: (Jay Blazed)
over 4g's on my b16
Old Aug 7, 2005 | 04:55 PM
Jay Blazed's Avatar
thats what im trying to stay below
not a B16A2 IS IT
i wonder what a ls motor with a b1a2 tranny will be at 80 mph
anyone?
Old Aug 7, 2005 | 09:36 PM
aj99si's Avatar
at 80mph a gsr will be at 4000 a b16 will be about 44 to 4500. A ls is somewhere around 35 to 3600.
Old Aug 7, 2005 | 10:47 PM
sickerhatch's Avatar
Default Re: (aj99si)
I have a gsr tranny on a b16a and im at 4500 at 80.With my old tranny a jdm b16a i was at right around 5000 or so.
Old Aug 8, 2005 | 11:46 AM
hybridEj6's Avatar
Default Re: (sickerhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickerhatch &raquo;</TD></TR><TR><TD CLASS="quote">I have a gsr tranny on a b16a and im at 4500 at 80.With my old tranny a jdm b16a i was at right around 5000 or so.</TD></TR></TABLE>
what size rims?
On 16" inch rims on 205-45's size tires im around 4500 rpm....this is a 96 type r tranny with a 4:40 final drive...with my old gsr tranny i was around 4000 at 80mph
Old Aug 8, 2005 | 01:42 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (ekhybrd)
With my ITR motor and trans, i am at about 5k at 80mph. 4.40 trans.
Old Aug 8, 2005 | 07:29 PM
Jay Blazed's Avatar
damn how do you guys go anywhere far
when i drive to the beach i like to be below 4k
Old Aug 8, 2005 | 07:52 PM
blackeg's Avatar
with 15's and 205/50's and a gsr tranny im at about 4100-4200 in 5th at 80mph. it is kinda annoying at first, but its really not that bad. i took the car to jers and back last weekend, about 150 miles each way, and im still getting in the low to mid 20 mpg range (which is directly affected by me boosting a lot ).
Old Aug 8, 2005 | 09:30 PM
EG92's Avatar
4200 with 205/45/15, gsr trans
Old Aug 9, 2005 | 04:44 AM
91civicDXdude's Avatar
205/50/15 4.40 final ~4500 @ 80mph
Old Aug 9, 2005 | 07:10 AM
EK_GSR's Avatar
Default Re: (91civicDXdude)
LS tranny 205/50/15 azenis, 80 mph, ~3650 rpm.
Old Aug 9, 2005 | 07:36 AM
blaze the chemi's Avatar
Default Re: (EK_GSR)
I had 215/35/19 on my 2000 Si with a B16 tranny. I didn't see a big decrease in RPM at the 80mph mark. I was still just over 4K instead of around 4300-4400. You'll need a smaller FD to get down into the mid 3K at the speed, but then you'll suck at acceleration. Maybe you can find a 5th gear stuff that would make the ratio larger so you can hit a smaller RPM at 80 mph. I have know clue on tranny stuff.
Old Aug 9, 2005 | 06:26 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (blaze the chemi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze the chemi &raquo;</TD></TR><TR><TD CLASS="quote">I had 215/35/19 on my 2000 Si with a B16 tranny. I didn't see a big decrease in RPM at the 80mph mark. I was still just over 4K instead of around 4300-4400. You'll need a smaller FD to get down into the mid 3K at the speed, but then you'll suck at acceleration. Maybe you can find a 5th gear stuff that would make the ratio larger so you can hit a smaller RPM at 80 mph. I have know clue on tranny stuff.</TD></TR></TABLE>
I would hope that you saw absolutely no difference; the wheel and tire size does not affect the indicated speed vs. RPM for a given gear period.
Old Aug 10, 2005 | 06:29 AM
Default Re: (Dogginator)
If you change the overall circumference of the wheels from the stock settings you will see a slight change. Do the math or go to this website.
http://www.1010tires.com/TireSizeCalculator.asp
The stock 2000 Si has 195/55/15 tires and I had 215/35/19. Therefore I would hit 80 mph before my speedometer would read 80.
Old Aug 10, 2005 | 06:54 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze the chemi &raquo;</TD></TR><TR><TD CLASS="quote">If you change the overall circumference of the wheels from the stock settings you will see a slight change. Do the math or go to this website.
The stock 2000 Si has 195/55/15 tires and I had 215/35/19. Therefore I would hit 80 mph before my speedometer would read 80.</TD></TR></TABLE>
I clearly stated indicated speed. I reiterate, you will see no difference in your speedometer reading vs. tachometer reading as a result of changing your tire diameter.
Old Aug 11, 2005 | 04:47 AM
Unless you recalibreate the speedometer, if that is possible, no you won't see a change. So you can't look at the speedometer to compare the RPM vs speed when you change the diameter of the wheel and tire. My speedometer would read 80 mph when I am actually going 85 so in essence my rpm's do change according to speed, even though my my gauges say otherwise. I now have OZ superleggera's with 205/40/17. There is no visual difference between this size and my stock size with respect to RPM vs Speed.
The point of this thread is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay Blazed &raquo;</TD></TR><TR><TD CLASS="quote">tring to get a good idea for a tranny swap in my ls</TD></TR></TABLE>
You can change your wheel and tire setup to help out a bit, but you definitely need a lower FD tranny to get down to that RPM vs. actual speed.
You can't argue with a cop to say that your speedmoter is wrong, otherwise he'll write another ticket for a malfunction within the car.
Or you can get those big wheels that you'd see on a rediculous escalade in a rapper's video. Get a 22' wheel and get 235/50/22 tires y0!. You'd have some serious rubbing issues HAHA, but your speedomter would ready 60, but your actually going 80 and a lower RPM's.
lilo_goki
Nov 13, 2007 05:46 PM
Slowboy!
Dec 8, 2005 11:09 AM
kazino42
Jul 31, 2005 05:35 AM
AzntstyleZ
May 19, 2003 08:54 AM
xtremcrx77
Jan 1, 2002 05:13 PM
