TEST-N-TUNE LAS VEGAS SPEEDWAY.......8/5/05 - wheelie bars??????
Old Aug 6, 2005 | 09:42 AM
og asr's Avatar
Default - wheelie bars?????? - Thank you BERGENHOLTZ RACING.................
I could not get the "wheelie bars" dialed in with the car.....any suggestions???
The bars kept making the car feel unstable down the track....
Please let me know...
All Squeeze Racing...
10.30@138mph....
LDL SPEED SHOP
http://www.we-todd-did-racing....5NTQx
Modified by og asr at 5:45 AM 10/11/2005
Old Aug 6, 2005 | 10:42 AM
Supernatural's Avatar
Default Re: TEST-N-TUNE LAS VEGAS SPEEDWAY.......8/5/05 - wheelie bars?????? (og asr)
how high are they off the ground on a flat surface?
did u go with a softer rear spring too?
Modified by SUPERNATURAL at 7:53 PM 8/6/2005
Old Aug 7, 2005 | 11:14 AM
og asr's Avatar
Default Re: TEST-N-TUNE LAS VEGAS SPEEDWAY.......8/5/05 - wheelie bars?????? (SUPERNATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPERNATURAL &raquo;</TD></TR><TR><TD CLASS="quote">how high are they off the ground on a flat surface?
Modified by SUPERNATURAL at 7:53 PM 8/6/2005</TD></TR></TABLE>
bell....they are about half an inch off the ground.......on flat surface....i didn't even change the rear springs...how soft should the rears be now??? they currently have 1,000lbs springs in the back..........
damn....this is so confusing trying to figure that perfect combination.
Old Aug 7, 2005 | 11:19 AM
bergenholtzracing's Avatar
Put 200 pounders in the rear so it hits the wheely bars hit earlier at the launch. Set rebound in the rear as hard as you can get it so it stay on the wheely bars longer. 1000 pounders are not gonna cut it with a whelly bar
Old Aug 7, 2005 | 11:53 AM
og asr's Avatar
Default Re: TEST-N-TUNE LAS VEGAS SPEEDWAY.......8/5/05 - wheelie bars?????? (bergenholtzracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bergenholtzracing &raquo;</TD></TR><TR><TD CLASS="quote">Put 200 pounders in the rear so it hits the wheely bars hit earlier at the launch. Set rebound in the rear as hard as you can get it so it stay on the wheely bars longer. 1000 pounders are not gonna cut it with a whelly bar</TD></TR></TABLE>
Thanks Ron or Ed.....you don't 200 lbs springs in the back is too soft? I will try it....thanks for the tips......
Old Aug 12, 2005 | 01:32 AM
meancivicsi's Avatar
what happened to the rex in the last run of that vid? the one w/o wheelie bars? it looked like you went up in smoke towards the end there.
Old Oct 11, 2005 | 04:44 AM
og asr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by og asr &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks Ron or Ed.....you don't 200 lbs springs in the back is too soft? I will try it....thanks for the tips......</TD></TR></TABLE>
I followed your advise......and we finally hit the 9's......9.94@145.7mph.....
Thank you ED or RON for the "sound" advise. I still "bow down" to you O.G.'s in this racing scene.
Again THANK YOU&gt;
All Squeeze Racing
LDL SPEED SHOP
Old Oct 11, 2005 | 07:17 AM
SVPCEO's Avatar
sup randy,so you see a big differance in your 60 foot when you made the change? what shocks & springs you running..........
redDAinteg
Sep 3, 2007 03:21 AM
vinuneuro
Suspension & Brakes
12
Jun 26, 2006 08:47 AM
Chong
Suspension & Brakes
20
May 22, 2005 11:24 AM
D50boy
10
Mar 4, 2004 06:06 PM
Robb
Apr 30, 2003 04:26 PM
