white smoke when vtec engages?
Old Aug 6, 2005 | 09:04 AM
Tuner Eddy's Avatar
Default white smoke when vtec engages?
i just noticed this morning on my way to work some white smoke coming out of my exhaust. Now the car is only doing this once my primaries hit, then once my secondaries hit a tad bit more starts to come out. It's not alot of smoke, but enough for me to see it in my rear view. Any suggestions? Should i be worried?
btw, car is a 1992 dx hatch with a gs-r swap.
Old Aug 6, 2005 | 10:03 AM
Tuner Eddy's Avatar
Default Re: white smoke when vtec engages? (Shift_Vtec)
bump
Old Aug 6, 2005 | 10:16 AM
Mr_Eg_Hatchback's Avatar
Sounds like you are running too rich. Black smoke is oil and white or light grey smoke is fuel.
rgrs
Old Aug 6, 2005 | 10:21 AM
Suck my DX's Avatar
Default Re: white smoke when vtec engages? (Mr_Eg_Hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Eg_Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you are running too rich. Black smoke is oil and white or light grey smoke is fuel.
rgrs
wrong
white smoke = coolant
blue smoke= oil
black smoke=running too rich
stop giving people bad advice
Old Aug 6, 2005 | 10:30 AM
Default Re: white smoke when vtec engages? (Suck my DX)
Thank you for setting me strait, suck my DX!
Old Aug 6, 2005 | 10:34 AM
EG_Jefro's Avatar
no its more like black smoke is shitty old oil and white / grey smoke is clean good oil ... it sounds like you might need to replace your piston rings if its smoking when your getting up in the higher rpms you might be able to get away with some thicker oil but it will most likely get progressive but the oil might keep it from smokin good luck !
Tuner Eddy's Avatar
so what does it mean when im burning coolant?
all i know is when my friend blew his headgasket he was pouring out white smoke, but that was after it blew. so any suggestions?
Old Aug 6, 2005 | 10:36 AM
EG_Jefro's Avatar
Default Re: (Shift_Vtec)
is it running hot?
Old Aug 6, 2005 | 10:40 AM
Tuner Eddy's Avatar
Default Re: (EG_Jefro)
no not at all, the car runs at normal temperature right below the middle of the temp gauge
Jay Blazed's Avatar
Gasket Kit
Old Aug 6, 2005 | 10:42 AM
EG_Jefro's Avatar
well if its burning coolant its more than likely your head gasket is about to blow and coolant is leakin and burnin up thats where your getting your white smoke so invest in a headgasket pretty soon should fix your troubles
Old Aug 6, 2005 | 10:43 AM
Tuner Eddy's Avatar
should i be alright for awhile as long as i dont beat on the car?
Old Aug 6, 2005 | 10:46 AM
EG_Jefro's Avatar
yeah you could drive it till the headgasket blows
Old Aug 6, 2005 | 11:31 AM
Tuner Eddy's Avatar
krazyk606
Feb 19, 2008 08:11 PM
-[uSa]-Defcon_07
Aug 5, 2007 10:28 AM
CRX_Control
Nov 10, 2004 09:29 PM
1990civicsi
Aug 8, 2004 06:33 PM
SIK IN DA HED
Jan 6, 2004 09:24 AM
