why does my rpm's increase when im in neutral
Old Aug 6, 2005 | 08:07 AM
hatchinprogress's Avatar
Default why does my rpm's increase when im in neutral
this just started to happen this morning, when im driving the car it seemed to be fine but when im at a stop the rpms stick at around 4k(rpm) and my ecu is chipped with a 3.5k rev limiter(chip made be xencron, so its a good chip) and if i throw the car in nuetral the rpm's will climb and stick at 4k.....now why would that happen??
the cae is a 91 civic ef i have a dohc zc with a t-25 turbo and the ecu is a pr4 chipped(chip made be xencron) ive this set-up for a while(since jan.) and this just started today.
Old Aug 6, 2005 | 08:45 AM
Default Re: why does my rpm's increase when im in neutral (hatchinprogress)
bizump
Old Aug 6, 2005 | 09:04 AM
1G_DX_to_2G_Si's Avatar
wait, is it an automatic? or do you mean just out of gear on a 5 speed? 3.5k rev limiter?
maybe i'm just being retarded but thats one hard to understand question. all i would think is check your vacuum lines, and throttle cable.
Old Aug 6, 2005 | 09:05 AM
Default Re: (1G_DX_to_2G_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1G_DX_to_2G_Si &raquo;</TD></TR><TR><TD CLASS="quote">wait, is it an automatic? or do you mean just out of gear on a 5 speed? 3.5k rev limiter?
maybe i'm just being retarded but thats one hard to understand question. all i would think is check your vacuum lines, and throttle cable.</TD></TR></TABLE> sorry if i didnt make sense, but yes it's a 5-speed and the 3.5k is a luanch control(2step) which means unless im in gear the car shouldnt go past 3.5k
Old Aug 6, 2005 | 09:55 AM
superbeastcrx's Avatar
Default Re: (hatchinprogress)
could be the fast idle valve sticking open.
Old Aug 6, 2005 | 09:59 AM
CRX_Control's Avatar
Default Re: (superbeastcrx)
I would check your intake manifold gaskets and throttle cable . I had this problem too during my swap but then i found out that my throttle body was releasing way too much air into the intake manifold.
kyle48_2007
Feb 6, 2010 10:31 PM
Razr2
15
Jan 1, 2008 10:24 PM
hatchinprogress
Aug 6, 2005 11:21 AM
1SlowSi
Feb 25, 2004 05:59 AM
Loveless
Jun 23, 2003 09:40 PM
