h22 clutch line
lookin at an h22 clutch line it has a line that goes into the shifter cable part and then into the slave cylinder...how would i make that for for a civic?? just put in clutch line in the slave cylinder? btw hmotorsonline has clean motors and alll the sensors were intact ==]
I'm confused on what your saying. I just took a motor out of the prelude and saw one clutch line. My civic with a h22 has one clutch line. You can use the stock clutch line or get a steel braided one like me for that bling y0. Acutaly mine started leaking had a crack some how. So i just replaced it with a braided line.
I'm putting a 22 in a civic and on the tranny the clutch line splits up, its a rubber line that goes into the shifter cable section then branches off into a steel line
BIGBLOCKEK
Sep 6, 2004 11:14 PM
