which p/s bracket?
Old Aug 6, 2005 | 05:13 AM
tthumma10's Avatar
Default which p/s bracket?
I'm swapping a 99 gsr into an ek civic, which power steering bracket do i need?
Old Aug 6, 2005 | 11:06 AM
tthumma10's Avatar
Default Re: which p/s bracket? (tthumma10)
bump
Old Aug 6, 2005 | 11:16 AM
EJ8VTEC's Avatar
Mr. Indecisive
i think u have to use the d series bracket, belt wont fit 100% but it works. I heard if u use a certain belt it will fit perfect, mine is a little tight. I have a b16 and i believe im using d series ps bracket w/ a b16 ps belt. Ill look when i get a chance at the part # if u want me to.
Old Aug 6, 2005 | 12:33 PM
tthumma10's Avatar
Default Re: which p/s bracket? (EJ8VTEC)
thanks for the reply. I have my d-series p/s bracket, but only the two bottom bolt holes line up with the gsr mounting location. the d-series is a one piece bracket, but i think the gsr uses two pieces. i'd like to re-use my pump if possible...
Old Aug 6, 2005 | 06:43 PM
EJ8VTEC's Avatar
Mr. Indecisive
you might want to use the del sol one, that might work from the del sol vtec. that ac bracket worked for me, the p54 i believe. but then again i have a b16 n ur also talkin about the ps pump
i forgot to look when i got out of the office, but i will def check for u to see which one i have
eghatch07
Transmission & Drivetrain
Jan 4, 2014 11:52 PM
Mentat Ghola
Feb 24, 2009 01:47 PM
jadugartir
Aug 19, 2006 12:30 PM
redsled00
Oct 14, 2005 06:39 PM
rice_classic
11
Mar 10, 2002 12:01 AM
