Launching a 97 prelude!
Old Aug 5, 2005 | 11:49 PM
97 Sleeper's Avatar
Default Launching a 97 prelude!
Was up guys need some help from the pros. wat is the best way to launch a 97 prelude??? and at how many thousand to shift to second??? thanks for all input!
Old Aug 5, 2005 | 11:52 PM
Shakes's Avatar
space cadet
Default Re: Launching a 97 prelude! (97 Sleeper)
launching is all up to you. try different revs and get a feel for what you like. shift at about 7,000 - 7200 on the OEM tach. 6800-7000 on anything else.
Old Aug 6, 2005 | 12:58 AM
VtecLover's Avatar
Default Re: Launching a 97 prelude! (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">launching is all up to you. try different revs and get a feel for what you like. shift at about 7,000 - 7200 on the OEM tach. 6800-7000 on anything else.</TD></TR></TABLE> why would you want to shift at 6800-7000 on anything else. If you have a vfac would that be more accuate then anything else since you stock is most of the time off by 100 or so RPM?
Old Aug 6, 2005 | 12:59 AM
VtecLover's Avatar
Sorry I cant spell or type
Old Aug 6, 2005 | 01:04 AM
Shakes's Avatar
space cadet
Default Re: (VtecLover)
yes, aftermarket tach's that go above 8k and digital tach's would be more accurate.
the OEM prelude tach is known to be off a couple hundred RPM's in the high end which is normal.
when a gauge is calibrated, the center of attention is on 20 - 80 % of full range. anything under and over is going to be the least accurate.
TeGGY_LS
Jul 21, 2008 06:29 AM
xi abla ix
May 19, 2006 09:55 PM
cpforyou
Dec 2, 2005 12:16 PM
cbmprelude
Mar 19, 2004 12:52 PM
PetroGuyX
May 3, 2003 08:54 AM
