Valve sticking out a bit...why?
Old Aug 5, 2005 | 08:49 PM
AThiker's Avatar
Default Valve sticking out a bit...why?
Just pulled cylinder head off a b16a and found that one of the valves is sticking out a little bit like the one seen in this photo...
Is this normal? Anything I should do?
TIA
Old Aug 5, 2005 | 09:00 PM
onepoint6i's Avatar
Default Re: Valve sticking out a bit...why? (AThiker)
...hmmm i've never seen that..you only see that on single cam heads cause obviously the cam is still on the head..
But why did you pull the head? i would remove the keepers/spring and check out the valve,guide etc.. thoroughly if i were you...more than likely its bent it seems..
Old Aug 5, 2005 | 09:06 PM
AThiker's Avatar
Default Re: Valve sticking out a bit...why? (1.6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i &raquo;</TD></TR><TR><TD CLASS="quote">...hmmm i've never seen that..you only see that on single cam heads cause obviously the cam is still on the head..
But why did you pull the head? i would remove the keepers/spring and check out the valve,guide etc.. thoroughly if i were you...more than likely its bent it seems..</TD></TR></TABLE>
I'm selling the head. The motor ran fine, so would it run normally were it bent?
Old Aug 5, 2005 | 09:12 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AThiker &raquo;</TD></TR><TR><TD CLASS="quote">
I'm selling the head. The motor ran fine, so would it run normally were it bent?</TD></TR></TABLE>
no it wouldnt, it should be fine then..just remove, or even tap on the spring. Maybe it's just stuck somehow..
BTW how much you slanging the head for?
Old Aug 5, 2005 | 09:22 PM
AThiker's Avatar
Here is another pic of a different head with the same issue:
I'm going to be putting on ebay sometime. Got to pick up a few more things for it and clean it up a bit.
Old Aug 6, 2005 | 07:07 AM
AThiker's Avatar
Anyone else have any input?
Old Aug 6, 2005 | 07:35 AM
NJIN BUILDR's Avatar
The valve is bent or the stem is suck in the guide (either rust or galled).
Glenn
Old Aug 6, 2005 | 08:06 AM
AThiker's Avatar
Default Re: Valve sticking out a bit...why? (NJIN BUILDR)
Could it be that because the cams are installed they are pushing on some valves keeping them open like that?
Old Aug 6, 2005 | 08:47 AM
d16dcoe45's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The valve is bent or the stem is suck in the guide (either rust or galled).
Glenn</TD></TR></TABLE>
Exactly--I would say the valve might be a tiny bit bent--all it takes is a little to have it hang up in the guide.
Old Aug 6, 2005 | 09:21 AM
AThiker's Avatar
Default Re: Valve sticking out a bit...why? (d16dcoe45)
Almost every honda/acura cylinder head on ebay right now has at least one valve sitting the same way...
Here is another...
Old Aug 6, 2005 | 10:06 AM
flatblackracing's Avatar
if the cams are in the head with the caps installed, then yea some valves will be opened somewhat
Old Aug 6, 2005 | 10:57 AM
Crazydave's Avatar
Default Re: Valve sticking out a bit...why? (flatblackracing)
turn the cam through it's cycles and see if the valve moves
Old Aug 6, 2005 | 11:10 AM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AThiker &raquo;</TD></TR><TR><TD CLASS="quote">Could it be that because the cams are installed they are pushing on some valves keeping them open like that?</TD></TR></TABLE>
you have the cams installed on the head???...I replied thinking the cams were off the head..If the cams are on, obviously the valves are going to be open depending on cam position...
Old Aug 6, 2005 | 12:00 PM
If the cams are installed then obviously the lobe is holding it open.Why did you have to even ask this question.
Glenn
Old Aug 6, 2005 | 12:18 PM
mikestypes's Avatar
If the cams where still in the head, both valves on the cylinder would be open.
Old Aug 6, 2005 | 04:03 PM
onepoint6i's Avatar
Default Re: Valve sticking out a bit...why? (mikestypes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypes &raquo;</TD></TR><TR><TD CLASS="quote">If the cams where still in the head, both valves on the cylinder would be open.</TD></TR></TABLE>
no, it all depends on cam position ...
your on the right track though...more valves would probably be open...
we need to see if the cams were really bolted on the head or not...TTT
Old Aug 6, 2005 | 05:38 PM
b18ccivics's Avatar
it is bent.
Old Aug 6, 2005 | 10:08 PM
AThiker's Avatar
I'll take the cams out and see if it moves. Thanks folks.
CivicxTree754
Feb 9, 2011 08:05 AM
bsmith100
10
Jun 12, 2008 08:36 PM
le0ftw
Nov 22, 2006 05:13 PM
ol'rex
May 6, 2006 11:37 PM
hybridEj6
Oct 8, 2004 05:49 PM
