wheel stud broke today need help!!!!!!!1
Old Aug 5, 2005 | 08:02 PM
bbrian's Avatar
Default wheel stud broke today need help!!!!!!!1
hey can anyone tell me what part im gonna need to fix this , today i went to put my steelies on the front and when i took my rims off one of the lug nuts wasnt gettign loose so i tugged on it a little bit and boooom the bitch broke off with the bolt i dunno what piece i need to fix so if anyone can help id apreciate it thanks....
Old Aug 5, 2005 | 08:09 PM
tyro's Avatar
Default Re: wheel stud broke today need help!!!!!!!1 (bbrian)
I think you may have to take off the hub and replace the wheel bolt, but don't quote me on this one! I'll go take a look at the Helms..
Old Aug 5, 2005 | 08:24 PM
CRX_Control's Avatar
Default Re: wheel stud broke today need help!!!!!!!1 (Buck Turgidson)
yeah , you need to remove the hub and get another stud to replace the one you broke .
Old Aug 5, 2005 | 08:27 PM
tyro's Avatar
Default Re: wheel stud broke today need help!!!!!!!1 (CRX_Control)
Looking at the civic bible, I can't tell from the drawings whether the hub and bolts are a single piece or not. Honda parts website shows a bolt called "wheel bolt" which I think is the stud.
Old Aug 5, 2005 | 09:02 PM
Voodooboy520's Avatar
Yeah so I dont want to be an ******* or anything, but I crossthreaded one of mine, there are a few guides archived here.
Old Aug 5, 2005 | 09:12 PM
NCRXSi's Avatar
Default Re: (Voodooboy520)
Here's a write up on replacing the wheel stud without removing the hub. (Normal practice is unfortunately to remove the freaking hub, but this technique works too.)
Stud Replacement
Old Aug 5, 2005 | 09:20 PM
tyro's Avatar
Default Re: (NCRXSi)
That's a great writeup. Don't know if I would do it all with a Dremel however!
Old Aug 5, 2005 | 09:21 PM
N_A_is_best's Avatar
dude dont spend the money do it the old fashion way...
1. take the caliper off
2. take a grinder and cut a small 1inch cut in the hub
3. hammer out each stud
4. intall new stud
5. use washers on the new stud and tighten it
6. now your an OG and fixed your own hub
goodluck its easier than you would expect......
james
Old Aug 6, 2005 | 06:09 AM
Tyson's Avatar
Default Re: wheel stud broke today need help!!!!!!!1 (N_A_is_best)
you can grind the knuckle to make clearance for the stud, so you dont have to grind each stud. but dont hammer on the hub while its still on the spindle.... youre gonna end up put a huge dent on the bearing. use something to press it out, like a C clamp or something.
streetracer_305
18
Jun 20, 2015 01:59 PM
dre2day
Feb 16, 2008 07:56 AM
x_tc-Dae
Apr 13, 2006 12:03 PM
Cheivic
Jul 11, 2003 12:54 AM
jap_tek
Apr 4, 2003 09:01 AM
