Brake swap question???
Old Aug 5, 2005 | 05:46 PM
eg94si's Avatar
Default Brake swap question???
I just swapped in 99-00 Si brakes front&rear on my 96 Ek hatch DX, also the proportioning valve was change'd... but the brakes feel a bit mushy I am going to bleed the system which that might fix the problem but, I was wondering if I could just swap in a 94 RS integra brake booster... and if its worth it.???? Any help would be appreciated. Thank you
Old Aug 5, 2005 | 06:33 PM
JICB16B's Avatar
Default Re: Brake swap question??? (eg94si)
what proportioning valve did you use
Old Aug 5, 2005 | 10:34 PM
eg94si's Avatar
Default Re: Brake swap question??? (JICB16B)
I believe is its a 40/40... something like that.. the one of the Si as far as I know.
Old Aug 6, 2005 | 08:02 AM
eg94si's Avatar
up..
Old Aug 6, 2005 | 08:50 AM
EL Vap133's Avatar
You didn't bleed it at all?
Old Aug 6, 2005 | 09:04 AM
eg94si's Avatar
Default Re: Brake swap question??? (EL Vap133)
The system was bled half ***... I know I have to bleed the system again but, I am just trying to find out what booter to use.
Old Aug 6, 2005 | 10:01 AM
pdiggitydogg's Avatar
The ex mc will not leave "mushy as hell" brakes. Bleed it better and it will firm up - not as well as a larger unit, but still just as well as stock em1.
Old Aug 6, 2005 | 12:08 PM
j_wod2000's Avatar
i kinda have the same problem i got rear discs of a 95 si to my 94 dx, i didnt get the proportioning valve cause the si had anti lock brakes nor did i get the brake booster. is it real important to use the brake booster or is the proportioning valve all that is needed?
Old Aug 6, 2005 | 01:43 PM
eg94si's Avatar
Default Re: Brake swap question??? (j_wod2000)
I'll let you know how much of a difference it is if any, once I bleed the entire system. Then, again I also be installing sloted rotors, SS lines, and pads.
Old Aug 6, 2005 | 02:17 PM
BlueIntegraBoy's Avatar
Yes, bleed the system properly. I did my rear discs and bled them about 6 times each and my pedal is pretty firm.
Old Aug 6, 2005 | 04:02 PM
eg94si's Avatar
Default Re: Brake swap question??? (BlueIntegraBoy)
Thanks for all the help guys.. but, I still did not get an answer on what booster to run
Old Aug 6, 2005 | 05:44 PM
Si 7/8" MC or Integra 1" MC
hatchet_honda
Oct 10, 2010 10:04 PM
95_GSR_SEDAN
29
Nov 15, 2009 12:21 PM
EJ8VTEC
Aug 6, 2005 11:23 AM
Hackbackb18c1
Apr 20, 2005 08:03 AM
ek9800
11
Mar 3, 2005 06:47 AM
