Swap, won't start, getting spark and fuel... :(
Old Aug 5, 2005 | 04:04 PM
roxy2000's Avatar
Default Swap, won't start, getting spark and fuel... :(
I just replaced the engine in my civic and it won't start. Same engine used in swap. Both engines were running before they were removed. (one from a car with bad body damage, other from car with engine issues) I am getting spark and fuel. The main relay also seems to be fine. Any suggestions on what to try next?
I am thinking maybe the distributor (I had issues with one on my old Del Sol where I was getting a little spark but not enough to start)
What about timing? The replacement engine has been sitting in my garage for about 6 months but I didn't remove anything?
Any help would be greatly appreciated!
Old Aug 5, 2005 | 06:04 PM
ExiledinIN's Avatar
Default Re: Swap, won't start, getting spark and fuel... :( (roxy2000)
Make sure your ground is attached firmly. I made a silly mistake and my ground wasn't tight against the body.
Old Aug 5, 2005 | 06:17 PM
kingmonkey's Avatar
Could be timming. Did use your old dizzy or was one already on the new engine? If so, that might be your problem. You might not have it timmed right. Had this happen to me once or twice.
Old Aug 5, 2005 | 06:21 PM
SoftieB16's Avatar
Default Re: Swap, won't start, getting spark and fuel... :( (ExiledinIN)
I say check ur grounds and remember to remove the paint from where ur gonna ground it
Old Aug 5, 2005 | 08:03 PM
B.'s Avatar
B.
400 HP Club
Default Re: Swap, won't start, getting spark and fuel... :( (SoftieB16)
dizzy, ground on the BATTERY!! make sure your TPS and map sensors aren't switched up either it will start but run like **** if they're switched
Old Aug 6, 2005 | 02:34 PM
roxy2000's Avatar
Default Re: Swap, won't start, getting spark and fuel... :( (B.)
I've checked all of the grounds, they're good (even sanded surfaces of the ground connector and the body)
Checked the ICM in distributor and replaced with one from another running engine.
All spark plugs are firing
There is gas in the fuel filter
There is gas in the fule rail
Fuel injectors are shooting out gas
I've checked the main relay, its good.
Is there a way to check the timing without the engine running? My haynes manual says to check when running, but it won't start!!!
Old Aug 6, 2005 | 04:40 PM
roxy2000's Avatar
Replaced the TW sensor
Replaced the Coil
Checked thermostat ground
Still no start...
Old Aug 6, 2005 | 05:07 PM
roxy2000's Avatar
I checked the compression (with the engine cold, because it won't start)
Here's what I got:
Cyl 1 - 45
Cyl 2 - 50
Cyl 3 - 75
Cyl 4 - 105
Haynes manual recommends 184 regular, 135 minimum. Should the compression be this low where the engine is cold?
Old Aug 7, 2005 | 02:25 PM
moyo_rican's Avatar
Here you go this just happened to me last week. Pull out your dizzy and rotate the plug that goes into the head 180 degrees. I had this same problem last week the car had fuel and spark the timing was 180 out.
Old Aug 16, 2005 | 09:06 AM
88 rex's Avatar
did you find the problem?
I'm having the same problem
Old Aug 16, 2005 | 09:23 AM
CRXified's Avatar
Default Re: Swap, won't start, getting spark and fuel... :( (JUMPTHELIGHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUMPTHELIGHT &raquo;</TD></TR><TR><TD CLASS="quote">Here you go this just happened to me last week. Pull out your dizzy and rotate the plug that goes into the head 180 degrees. I had this same problem last week the car had fuel and spark the timing was 180 out.</TD></TR></TABLE>
this is what i was going to suggest
Old Aug 16, 2005 | 12:34 PM
tpr's Avatar
tpr
With compression numbers like that it will not fire and run. Is the cam properly timed to the crank?
it should have 120-180 PSI with less than 5% variation cyliner to cylinder.
tambara
16
Apr 20, 2008 01:01 PM
b20vtechatch
Mar 21, 2006 10:15 AM
biggmike2
Jan 21, 2004 10:56 PM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
