24.5x7x13 how many psi?
Old Aug 5, 2005 | 02:24 PM
BoOsTiN Dc2's Avatar
Default 24.5x7x13 how many psi?
How many psi should i run on 24.5x7x13 slicks? Power level at around 370 @ 9 psi and 600 @ 26 psi.
Old Aug 5, 2005 | 03:13 PM
jpenman50's Avatar
Default Re: 24.5x7x13 how many psi? (tRaCeBuStAbUsTeR)
I would start at 7 psi cold, and go from there. See how the track prep is and adjust off of that.. You may end up wih 4-5 psi in the tires for the best results. Only you can determine that though from the conditions you are faced with...
Old Aug 5, 2005 | 11:21 PM
Default Re: 24.5x7x13 how many psi? (jpenman50)
yeah i didnt go below 7 1/2 psi
Old Aug 6, 2005 | 10:33 AM
BoostedJeff's Avatar
those slicks are a bit small for you 600whp
Old Aug 6, 2005 | 11:15 AM
TurboTegB18c's Avatar
Default Re: 24.5x7x13 how many psi? (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">those slicks are a bit small for you 600whp</TD></TR></TABLE>
Agreed, need to step up!
Old Aug 6, 2005 | 11:37 AM
Default Re: 24.5x7x13 how many psi? (TurboTegB18c)
i was practicing off of 9 psi of boost so thats around 370... not that bad
Old Aug 6, 2005 | 09:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">i was practicing off of 9 psi of boost so thats around 370... not that bad </TD></TR></TABLE>
true. I expect 600whp and am going to be using 24.5x9/13 M/Ts until i burn them up and then upgrade to the 25's
ochsy03
Nov 4, 2005 07:33 PM
AznPrideYo
May 27, 2004 09:08 PM
TurboEG6
Feb 9, 2004 10:41 AM
sikcrx80
Aug 4, 2003 09:23 AM
