NEED HELP FAST PLZ
Old Aug 5, 2005 | 01:35 PM
91DroppedHatch's Avatar
Default NEED HELP FAST PLZ
ok, i bought the car a couple of days ago (1990 hatch w/ZC) and it all was fine, it came with the swap. the later on the CEL turned on, also the little gray box in the upper right corner of the hood has like a part that braches off and is connected to a wire harness, that part snapped but im not thinking its anything because the metal part is touching plastic so i figure its nothing. Also, I did get my car running again for a second and when i did i tried to turn on the headlights and when i did **** started buggin out then it shut off again. I got the car to run again by moving the snapped part to the ignition box around so im thinking its somthing around there, the ECU was throwing a code with 8 blinks so im gunna check on that. I did check the battery and its fine, also checked all of the fuses and there all good.
Old Aug 5, 2005 | 01:58 PM
CBURKE's Avatar
do you mean the little box on the passinger side? thats the injector box. that is what makes you have MPFI. if that is broke then yes it would mess up the car.
Old Aug 5, 2005 | 02:01 PM
nbi its on the drivers side, im thinkin its the igntiion box. it has a screw that holds it to the frame
Old Aug 5, 2005 | 04:41 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: (91DroppedHatch)
Injector resistor box, and without it you wont get fuel. Code 8 is Top Dead Center Position Sensor (TDC).
brian1991
16
Oct 11, 2009 01:56 AM
91DroppedHatch
Aug 5, 2005 04:44 PM
milf H U N T E R
Jun 26, 2002 10:34 PM
