Brake swap
Old Aug 5, 2005 | 12:47 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Brake swap
Easiest n cheapest way to get disk brakes in the rear. I have a 2000 civic ex, i figure the 99-00si brakes?? What pieces do i need, cause i might know some1 that is parting out their old si.
Old Aug 5, 2005 | 01:45 PM
bradykiller's Avatar
Default Re: Brake swap (EJ8VTEC)
You can also use 94-01 integra rear brakes.. exactly the same as 99-00 SI.. and alot easier to come across.
You'll need.
The trailing arm and hub assemblys.. which should have the rotor/caliper on them obviously.
Ebrake cables from a 99-00 SI.
And you'll probably want to upgrade your Prop valve to a 4040, and your Brake MC.
And while you're at it slap on some SS Brake lines.
Old Aug 5, 2005 | 01:50 PM
BlueIntegraBoy's Avatar
Default Re: Brake swap (bradykiller)
The prop valve wont be labeled 4040 of course. Make sure you get one from an Si or DX hatchback. A 7/8" Si MC would be great as well as a 1" Integra MC. I heard horror stories of SS lines when dirt gets in between the fittings and the braids. Stock lines are fine for daily driving.
Old Aug 5, 2005 | 05:38 PM
nighttrain33's Avatar
Default Re: Brake swap (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradykiller &raquo;</TD></TR><TR><TD CLASS="quote">You'll need.
Ebrake cables from a 99-00 SI. </TD></TR></TABLE>
You don't need the trailing arms, but it is a whole heck of a lot easier to do the swap than taking just the hub assembly off.
-Shane
Old Aug 5, 2005 | 06:37 PM
JICB16B's Avatar
i used a 00 proportioning valve on mine 00 ex but kept the stock ex master and works great. Good pedal feel. has anyone tried the ex master then switched to the integra? was there any noticable differences
Old Aug 6, 2005 | 09:15 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Brake swap (JICB16B)
bump for ^... i need to save money any way possible for now
Old Aug 6, 2005 | 09:19 AM
I guess the cheapest way would be to go to a junkyard, unless you can get some from a local shop or a friend. The only reason I say this is because in the junkyard, the parts may not be in such great condition. I got mine from a shop that I go to often to get parts, so he gave me a pretty good deal for his 'Teg parts.
-Shane
Old Aug 6, 2005 | 11:14 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Brake swap (nighttrain33)
Is this a do it yourself job, or should i take it to someone??
Old Aug 6, 2005 | 11:23 AM
EG-SI(rII)'s Avatar
DIY, just make sure you have about 2 hours, and secure your jackstands. That is, if you don't have a lift and air tools; if you do it should only take about 45 minutes-1 hour.
p.s. an extra jack helps to line up the trailing arms.
Cap'N Chronic
Mar 27, 2022 07:16 AM
GeoMetry
Nov 11, 2015 09:20 AM
jagumbel
Jun 15, 2009 10:29 AM
elnoyl
May 6, 2009 05:38 PM
Fugeeu
Aug 11, 2004 12:26 AM
