Suspension & Brakes Theory, alignment, spring rates....
quick camber kit adjustment question
Old Aug 5, 2005 | 12:09 PM
LoseRPunKx182's Avatar
Default quick camber kit adjustment question
which way do i go to make it positive or negative. i have an ingall camber kit.
Old Aug 5, 2005 | 12:13 PM
AutoXer's Avatar
Default Re: quick camber kit adjustment question (LoseRPunKx182)
Neg camber / \
Pos camber \ /
When looking at the front of the car.
Old Aug 5, 2005 | 12:19 PM
so i pull it out towards the outside of the car...hmmm..didn't do much for my camber hahah
Old Aug 5, 2005 | 12:27 PM
AutoXer's Avatar
Default Re: (LoseRPunKx182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">so i pull it out towards the outside of the car...hmmm..didn't do much for my camber hahah</TD></TR></TABLE>
You mean you're just eye-balling it? What's the specific problem you are having?
Old Aug 5, 2005 | 12:29 PM
i'm dropped on skunk2 coilovers on tokico about 2.5' and the negative camber is killing my tires. i am taking it to get an alignment soon but i got this kit to help it some more but it's still really negative but it's the black ingall kit and only suppose to be 1degree+
Old Aug 5, 2005 | 12:36 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">i'm dropped on skunk2 coilovers on tokico about 2.5' and the negative camber is killing my tires. </TD></TR></TABLE>
No, the camber isn't killing your tires, the fact you didn't get an alignment is. Whenever the ride height is changed, the toe changes. Toe eats tires, and eats them faster if there is camber, but will still wear them even if your camber was zero. Go get an alignment, and then pick up some new tires.
Old Aug 5, 2005 | 12:43 PM
i will but its the fact that most shops needs me to raise my car up to stock height to do an alignment and then when i drop it..there would be no point to the alignment. thats why it's taking me so long to get an alignment..gotta find a shop that'll do it dropped or semi dropped...also why i got a camber kit to help till i can get an alignment
Old Aug 5, 2005 | 12:48 PM
thanks for ur help btw
Old Aug 6, 2005 | 10:57 AM
ohjolt2's Avatar
If this shop wont do the alignment with your car lowered then find a shop that isnt full of idiots that will do it. If your car is so damn low you cant get it on the rack then you should raise it anyway. If your having some kind of body kit issue trying to get the car on the rack you might have to take your lip/ splitter whatever off.
lilshady6796
Oct 22, 2008 07:17 PM
idc 91si
11
Nov 28, 2007 08:28 AM
i3luemrld
Feb 6, 2004 11:44 AM
Shorty C
Jun 24, 2003 12:24 PM
xstalkrx
Apr 24, 2003 05:37 AM
