0bd1 Intake Mani on HF ???
i just got a crx Hf .... But i gotta replace the i Intake Mani & TB... i have a complet 95 CX moter ...& was wondering if i could but the cx mani & TB on it ?? & if yes what all would i have 2 do ,,,would the TBS Work ???
Yeah, you can put the other throttle body and manifold in. You might have to open up the harness so that some of the sensor plugs reach the sensors. there might also be an extra coolant passage on the 95 cx manifold, but all you will have to do it put a " T " in it or plug it and you should be okay. Not quite sure on that. You might want to compare both manifolds and check how many hoses are coming out of each manifold so you can be sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hedtrip »</TD></TR><TR><TD CLASS="quote">Thanx .... i will eventully be converting 2 obd1 ,, & put the y8 mani on it .. but im just trying 2 get it 2 runn for the time being !</TD></TR></TABLE> you gonna do a swap with that too right? it would be pointless to put it on the hf motor (d15b6)
Valkin
10
Apr 20, 2011 09:28 PM
thebigone
Sep 22, 2008 01:07 PM
