CP piston rings - file to fit?
Old Aug 5, 2005 | 06:17 AM
B18EG6's Avatar
Default CP piston rings - file to fit?
Hey-
My pistons and rods are at the machine shop being balanced so I figured I would ask while they had all my stuff.
Are CP piston rings file to fit rings? What gap do they yield, from the factory?
Thanks!
Old Aug 5, 2005 | 07:17 AM
earl's Avatar
Default Re: CP piston rings - file to fit? (B18EG6)
You must file fit CP rings. CP Pistons come from the factory already balanced and so does most aftermarket connecting rods. You do not need to do this and you should get them back from your balancer and save your money.
Upper rings come with only about .005" of a gap and that is way to small. Ring gaps are normally the call of your engine builder based on several issues like turbo or nitrous use, etc.
Old Aug 5, 2005 | 12:49 PM
B18EG6's Avatar
Default Re: CP piston rings - file to fit? (earl)
Thanks Earl!
Where could I find some more information about gaps and my setup? I have a gsr with low compression oversized CP's running about 10-14 PSI of boost
Old Aug 5, 2005 | 06:38 PM
earl's Avatar
I like .018" on the upper and .020" on the middle ring
EusebioSam19
Oct 28, 2012 06:39 AM
dstappity
Feb 20, 2011 02:55 PM
eddiebuiltEK.
Sep 15, 2009 08:25 PM
crex23
Feb 2, 2006 05:41 PM
boosted k20
Dec 1, 2004 09:31 PM
