Which injectors?
Old Aug 5, 2005 | 06:16 AM
Redsun's Avatar
Default Which injectors?
Motor - B20 (12.5 cr) Skunk2 stg2 cams.
Currently running ITR injectors and tuned with VAFC. Are bigger injectors really necessary for a setup like this?
Old Aug 5, 2005 | 01:01 PM
BigBodySmith's Avatar
I would recommend them, I am running 310cc's in a ls/vtec with 12.5:1 compression and stg2 cams.
Old Aug 5, 2005 | 07:00 PM
b19coupe's Avatar
Default Re: Which injectors? (Redsun)
Yes. 310's would be a good start. Personally I like to go too big and tune out fuel with Hondata.
Old Aug 5, 2005 | 10:00 PM
rjay8604's Avatar
Default Re: Which injectors? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote"> Personally I like to go too big and tune out fuel with Hondata.</TD></TR></TABLE>
I think thats a good idea as well.
Old Aug 5, 2005 | 11:22 PM
Icey112's Avatar
Default Re: Which injectors? (rjay8604)
310 will work good or even 440's if you wanted to go with nitrous later on.
Old Aug 6, 2005 | 04:43 AM
Redsun's Avatar
Well i wont be spraying in future so, i'll try 310. What does it mean when it says - 'saturated' and 'peak and hold'?
Old Aug 6, 2005 | 01:04 PM
sangyi's Avatar
JDM H22a injector at 345CC!
Old Aug 7, 2005 | 12:37 AM
Redsun's Avatar
Default Re: (sangyi)
Anyone got any for sale?
C'mon guys, i need to know - what's Saturated? And whats peak and hold?
Old Aug 7, 2005 | 10:30 AM
asocallocal's Avatar
i got some obd1 h22a injector. its peak and hold. i believe peak and hold u will need to use a resistor which i have also. the sat. is just plug and play. peak and hold is cheaper than sat. P and H is from the ealier model cars like88-91 b16 and 92-up is Sat. thats all i know. pm me if u want them
Old Aug 8, 2005 | 04:05 AM
1750cc's Avatar
Default Re: Which injectors? (asocallocal)
since youre buying a set, id suggest you go with 370s or 440. just to be sure you can still deliver in high rpms.
MI4$DC5
Jan 29, 2005 10:55 AM
RACING INTEGRATION
Nov 29, 2004 08:10 AM
blykins
31
May 4, 2004 06:41 AM
Nice_Dc2r
19
Feb 24, 2004 05:34 AM
TimoneX
Jan 18, 2003 07:35 AM
