VSS where is it???
Old Aug 4, 2005 | 11:57 PM
all_motor's Avatar
Default VSS where is it???
My speedo recently went out and my cel is on. Does anybody have a picture they can post to show me where it is and how it looks like? I know its somewhere near the tranny but someone please tell me exactly where it is and how it looks like. Thanks!
Old Aug 5, 2005 | 12:03 AM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: VSS where is it??? (all_motor)
Do you have a swap? If it's cable, I'm willing to bet it's the cable...
Old Aug 5, 2005 | 12:05 AM
all_motor's Avatar
Default Re: VSS where is it??? (h8tred)
No, everything is stock.
Old Aug 5, 2005 | 12:22 AM
h8tred's Avatar
Then it's the cable. Or it could have came loose on the tranny, or the back of the cluster. Look at the top of the tranny near the firewall, you should be able to see the cable. I can get some pics tomorrow if need be. Just let me know.
Old Aug 5, 2005 | 12:26 AM
all_motor's Avatar
Yes pics would help a lot. I am a total noob at this. Thanks!
Old Aug 5, 2005 | 12:27 AM
h8tred's Avatar
I'm not going to lie to you, routing that cable is a total pain in the ***, and getting it to snap into the tranny too.
Old Aug 5, 2005 | 12:28 AM
all_motor's Avatar
Thanks for the heads up.
Old Aug 5, 2005 | 12:44 AM
h8tred's Avatar
What trim level do you have?
Old Aug 5, 2005 | 01:24 AM
h8tred's Avatar
Ok, you're gonna want to start by taking out the gauge cluster. There are four screws, and you'll have to disconnect the rear defroster, hazard, dimmer, and any other switches you may have on your cluster hood. Once that is off, you'll have four more screws, three harness plugs, and the speedo cable to unhook to actually remove the cluster. This is detailed in the workshop book, which I have available in .pdf format at http://users.adelphia.net/~h8t...l.pdf Please right click and save target as, so as to not kill my bandwidth.
Next, you'll want to go under the hood, and unclip the cable from the side of the rear transmission mount, feel around for the wire clip, and take that off. Then pull the boot up, and there should be a plastic clip built on to the end of the cable that holds it into the transmission. Then you'll want to pull the boot from the firewall. You're going to have to pull the cable out from under the hood. Try not to damage the boots, because I do not know if the new cable will come with them. Be patient, take breaks if you start getting pissed, because like I said this is indeed a pain in the ***. Here are the pictures I took for you, hope they help, and if you need any more help, just shoot a line on here.
Old Aug 5, 2005 | 01:55 AM
g24jr's Avatar
if its a cable speedo the cel wouldnt come on would it?
i bet you somethin else is wrong
Old Aug 5, 2005 | 02:02 AM
h8tred's Avatar
Default Re: VSS where is it??? (g24jr)
Yes, it would. You see, the Vss for cable speedos is in the speedo itself. Which in turn sends it's data to the ecu. However he should check just to be 100% sure, and to do that, first make sure the cable is snug into the tranny, and then pull the cluster out and take a short drive, watching to see if the part of the cable that goes into the speedo spins at all. If not, it's the cable, if it does, it's your speedo. I had the same thing happen to me, and 99.9% of the time the cable will go before the actual Vss in the Speedo. Hence my suggesting that it is in fact the cable.
Old Aug 5, 2005 | 02:04 AM
h8tred's Avatar
All this talk of Speedo makes me want to wear one!
Old Aug 5, 2005 | 02:06 AM
h8tred's Avatar
And help yourself to the PDF man, I also have the Vtec supplement too. Not on my server, but I can put it up if you want it.
Old Aug 5, 2005 | 02:54 AM
g24jr's Avatar
i got 2 points tooken away for askin for a online manual before
Old Aug 5, 2005 | 03:12 AM
h8tred's Avatar
I guess I can see why. It's there for you either way. All it is is a link on HT, my server, my manual. So the owners of this site can't be held responsible. There's about 100 other sites that have it as well, so it's whatever.
Old Aug 5, 2005 | 07:42 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Some of the pics here might also help you:
https://honda-tech.com/zerothread?id=1325930
Old Aug 5, 2005 | 04:35 PM
h8tred's Avatar
Default Re: VSS where is it??? (88DXCRX)
Nice pictures and write up.
Old Aug 6, 2005 | 06:17 AM
all_motor's Avatar
Wow. Thanks. I have a DX by the way. I'll check it out. Thanks a lot!!!!
sde780
May 27, 2009 03:51 PM
crxblues
Dec 6, 2006 10:44 AM
BigDawwg6969
Feb 25, 2006 05:35 PM
^MikeG
Oct 10, 2004 07:00 PM
tsjeff
Jul 22, 2003 07:39 PM
