Phillips screws that hold the rotor on the hub.
Old Aug 4, 2005 | 09:54 PM
GetawayInMoscow's Avatar
Default Phillips screws that hold the rotor on the hub.
Does anyone use these? My Civic is the first car I've seen that uses screws to hold the rotor on the hub. Everything else I've seen just uses the caliper plus lugs.
So do I need these or no?
Old Aug 4, 2005 | 09:58 PM
EK k kay's Avatar
Default Re: Phillips screws that hold the rotor on the hub. (GetawayInMoscow)
Not necessary. But I put em in anyway.
The Internet Tough Guy's Avatar
you don't need them
i've been rolling around without them for 18+ months
they're only there to hold the rotor on the hub while the car rolls down the assembly line at the factory. your wheel holds the rotor on just fine.
Old Aug 4, 2005 | 10:15 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Phillips screws that hold the rotor on the hub. (The Internet Tough Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Internet Tough Guy &raquo;</TD></TR><TR><TD CLASS="quote">they're only there to hold the rotor on the hub while the car rolls down the assembly line at the factory. your wheel holds the rotor on just fine.</TD></TR></TABLE>
Old Aug 5, 2005 | 02:15 AM
siregcivic's Avatar
yah when i got my hatch it was origionaly form ny... so when i went to change the rotors the screws were rusted so i drilled em out 2 years ago.. still fine
ZCMeGone
13
Jun 25, 2007 07:59 AM
MugenHonda
Jan 25, 2005 10:49 AM
92 CIVIC HATCH VX
Nov 13, 2004 04:22 PM
OEMaccord
Feb 7, 2003 02:28 PM
lordhuh
Jul 6, 2002 06:58 PM
