Oil pump problem, need help ASAP!!
Old Aug 4, 2005 | 06:42 PM
kasso's Avatar
Default Oil pump problem, need help ASAP!!
just got a GSR oil pump for my LS/V. when slowly revving the car to see the oil pressure, i notice that at like 4k rpm, the oil pressure goes to like ~72 psi (which i know is normal) and then just all of a sudden drops down to like ~58 psi. is this normal?? last time i lost oil pressure, i spun a rod bearing. im not trying to let this happen again.
Old Aug 4, 2005 | 06:46 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Oil pump problem, need help ASAP!! (kasso)
where is your vtec crossover set at? it might be dropping because of that
Old Aug 4, 2005 | 07:07 PM
earl's Avatar
It could be the check valve opening in the pump. You could try putting a .050" shim on the spring and see if that changes the rpm or pressure.
eg-gsr423
Oct 27, 2009 08:57 AM
kasso
Aug 7, 2005 02:31 PM
smokey2.0
Apr 20, 2004 01:33 PM
91integraLSVTEC
Sep 14, 2003 02:33 AM
