Hard to get into 3rd and 5th
Old Aug 4, 2005 | 04:25 PM
xxxxxxxxxxxx's Avatar
Default Hard to get into 3rd and 5th
OK, so I got a 96 Prelude VTEC, and lately 3rd and 5th have been acting up, if I do a spirited start on the highway I will grind going into 3rd or 5th unless I really go slow with the shift, then it doesnt grind at all, any ideas what the problem is/what I can do?
Thanks for the help!
Old Aug 4, 2005 | 05:29 PM
951dc5's Avatar
Default Re: Hard to get into 3rd and 5th (bjorgen)
that means your tranny is about to go.
Old Aug 4, 2005 | 06:07 PM
Default Re: Hard to get into 3rd and 5th (Prelude951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">that means your tranny is about to go. </TD></TR></TABLE>
**** does it really?
Old Aug 4, 2005 | 07:08 PM
951dc5's Avatar
yeah i had that experience with my old tranny before. It was grinding 3rd and sometimes 5th. I would have to shift in 3rd smoothly otherwise it'll grind like a bitch. Until then, my reverse gear closed the door on me and i wont be able to reverse. I grab a used tranny from the junk yard to solve. Prelude stinks..
Old Aug 4, 2005 | 07:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i had that experience with my old tranny before. It was grinding 3rd and sometimes 5th. I would have to shift in 3rd smoothly otherwise it'll grind like a bitch. Until then, my reverse gear closed the door on me and i wont be able to reverse. I grab a used tranny from the junk yard to solve. Prelude stinks..</TD></TR></TABLE>
Damn, thanks, I hope you're wrong, but that's the exact same problem that I have so you're probably right hehe, oh well I'll see
Old Aug 4, 2005 | 07:30 PM
pheurton-skeurto's Avatar
my tranny in my 5th gen has been acting the same way for a while now (10,000+ miles). guy that tunes my car swears that its going to go at anytime...also said that a while ago. time will tell...
Old Aug 6, 2005 | 09:40 AM
951dc5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjorgen &raquo;</TD></TR><TR><TD CLASS="quote">Damn, thanks, I hope you're wrong, but that's the exact same problem that I have so you're probably right hehe, oh well I'll see</TD></TR></TABLE>
Yeah you might want to shift easily if you want it to last longer. but it'll go soon..eventually.
Old Aug 6, 2005 | 10:14 AM
All-Motor H22A's Avatar
Before my tranny went, it started with the 3th and 5th gear.
Old Aug 6, 2005 | 10:27 AM
BB4vTak's Avatar
Default Re: Hard to get into 3rd and 5th (All-Motor H22A)
3rd was the first gear to go bad on my h23 tranny. followed by 5th and 2nd soon innopperable.. best of luck drive it easy if you want it to last.. care for your syncros
Old Aug 6, 2005 | 07:25 PM
LudeBoyLeRoy's Avatar
Default Re: Hard to get into 3rd and 5th (BB4vTak)
I have the exact same issues.....anybody ever had these same symptoms and fix it w/new syncros?? (rather than replacing whole tranny)
Old Aug 7, 2005 | 02:26 PM
951dc5's Avatar
Default Re: Hard to get into 3rd and 5th (LudeBoyLeRoy)
heard by the time you replace w/new syncros, it cost around the same as getting a junk yard trany. If i'm a expert honda mechanic myself, i'll do it myself.
Old Aug 7, 2005 | 02:29 PM
LudeyKrus's Avatar
First, most import trannies have problems with synchro's goin out kinda of soon.
Second, if it's affecting only 3rd and 5th, you may have bent a shift fork on the inside while shifting hard and forcing it in.
Old Aug 7, 2005 | 08:55 PM
Emberghost's Avatar
This is pretty crappy news, my 3rd grinds unless I put it in real soft. 2nd will grind a little if i put it in hard.
How much do h23 trannies cost about at junk yards and all?
Old Aug 8, 2005 | 12:10 AM
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">First, most import trannies have problems with synchro's goin out kinda of soon.
Second, if it's affecting only 3rd and 5th, you may have bent a shift fork on the inside while shifting hard and forcing it in.</TD></TR></TABLE>
This is what my friend was saying, is there any easy way to inspect this? Sorry I'm a real noob
Old Aug 8, 2005 | 03:28 PM
951dc5's Avatar
Default Re: (bjorgen)
tranny is no easy way inspecting inside.
Old Aug 8, 2005 | 08:22 PM
Jordans95si's Avatar
don't mean to jack thread but some times....once in a blue moon i grind the gears....i don't ever think to remember what ones....my tranny isn't going bad is it...just stupidity......and bad shifting...
Old Aug 10, 2005 | 12:09 AM
I'm really hoping it's just a bent shift rod
Old Aug 10, 2005 | 02:28 AM
Consistent1's Avatar
I have the same 3rd and 5th problem with my h22, been about 15k miles. as long as I don't slam it into 3rd Iam fine and 5th I have to press clutch to take it out of gear (4th), let clutch out then press the clutch again to put it into 5th, in order for 5th not to grind
Old Aug 11, 2005 | 04:13 PM
951dc5's Avatar
Default Re: (Consistent1)
the reason why you people have such problem gettin in clutch is you shift to hard. easy on the preludes, it's only a cruiser machine
BULL3TPR00F
Feb 14, 2012 10:00 PM
furnace
May 15, 2005 11:17 PM
951dc5
Jan 22, 2005 05:38 PM
MackDad
Aug 19, 2004 07:50 PM
