VSS - What's its purpose?
throwing a cel for my vss. Safe to drive still? What's the purpose of this sensor? Only thing wrong that I notice while driving is the typical speedometer not working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SNsLude »</TD></TR><TR><TD CLASS="quote">is that ALL it's for? just to tell you how fast you're going?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 »</TD></TR><TR><TD CLASS="quote">it'll still be safe to drive but your mileage won't be counting. and if it's a vtec model, vtec won't engage</TD></TR></TABLE>
Can anyone confirm that the h22's vss is vertical, as in the harness sticks straight into it from the top and the h23's are horizontal? I read a few people finding their sensors horizontal as that is what i found. Anyhow, if I were to buy a "vertical" vss, would that bolt up just fine to where my old vss was? I understand it's just one bolt for the sensor part right?
yup, h22 vss for the h22 tranny is vertical. i always remove the vss when i change the tranny fluid since its easier to fill pouring from the top.
not sure if an h22 vss will work on h23 tranny though. check the partsnumber on http://www.hondaautomotiveparts.com
The power steering lines running to the VSS are for the speed-changing power steering level. As in, at low speeds, you get more power assist than at higher speeds.
I see. thanks guys. My vss took a dump on me, but i dont want to buy a vss from an h22 tranny (vertical) if it doesnt bolt on to where my vss (horizontal) is. Gonna go check t he parts number now
weird. a vss for a 92 h23 isnt the same part as a vss for a 94 h23. However the 94 h23 and h22 do have matching vss part numbers though.
