Air--Fuel
Old Aug 4, 2005 | 01:57 PM
jdmh22luda's Avatar
Default Air--Fuel
Im putting in my air/fuel gauge and was wondering if ne one knew where the best place to tap into the red,black, and O2 wires at.
Old Aug 4, 2005 | 02:03 PM
steveobb4's Avatar
Default Re: Air--Fuel (jdmh22luda)
Where the engine harness connectors connect to the chasis harness would be easy to get too . Do you have a 4th gen or 5th?
Old Aug 4, 2005 | 04:33 PM
PrettyLude's Avatar
you can pin it at the ecu, or the white wire on the o2 sensor itself
Old Aug 4, 2005 | 09:54 PM
BB6racer's Avatar
do you have a wideband? otherwise it's just a nice little light show...
Old Aug 5, 2005 | 05:12 AM
jdmh22luda's Avatar
Default Re: (BB6racer)
i dont think i have a wideband---it might however, 4th gen lude
Old Aug 5, 2005 | 05:55 AM
pheurton-skeurto's Avatar
no thats a narrowband a/f meter. hope you didnt pay a whole lot for the guage because like bb6racer said its really just a pretty light show...
Old Aug 5, 2005 | 11:06 AM
jdmh22luda's Avatar
Default Re: (pheurton-skeurto)
it doesnt make an accurate read from rich to lean at all?
Old Aug 5, 2005 | 11:21 AM
577HondaPrelude's Avatar
Default Re: (jdmh22luda)
your stock O2 will only tell you if your R/F is greater than 14.7:1 or less than 14.7:1, it will not tell you how much greater or less it is. Thus you never know how rich or how lean you are.
stock O2 sensor is very much like a digital signal, either zero or 1 volt. It can be somewhat useful in that if your lean at WOT then you know something is wrong. As far as knowing how far off you are, and for tuning use it's crap.
Old Aug 8, 2005 | 06:09 AM
jdmh22luda's Avatar
Default Re: (577HondaPrelude)
hmm i guess then merry christmas, its goin to b a light show
Old Aug 8, 2005 | 11:24 AM
onefastrx7turbo's Avatar
Very true. Especially the autometer A/R gauge. A complete waste of money. as far as these gauges go, the Greedy one is best, but like bb6racer said, unless its a wideband, its kinda useless. Wideband o2 meters are expensive, and have a limited life. The sensor I use on my MoTeC has a life span of about 25 hours I think.
Neil
Old Aug 8, 2005 | 01:21 PM
AzCivic1.6's Avatar
Default Re: (onefastrx7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastrx7turbo &raquo;</TD></TR><TR><TD CLASS="quote"> Wideband o2 meters are expensive, and have a limited life. The sensor I use on my MoTeC has a life span of about 25 hours I think.
Neil</TD></TR></TABLE>
don't some cars come w/ wideband o2 sensors? i've never heard of a 25hour lifespan.
Old Aug 8, 2005 | 02:34 PM
Default Re: (AzCivic1.6)
no, no stock car comes with a wideband 02 sensor
neil
Old Aug 8, 2005 | 02:37 PM
pentaq's Avatar
wrong...
civic vtec-e comes with wideband NGK, some vw also (bosch and ngk).
Old Aug 8, 2005 | 03:09 PM
Default Re: (pentaq)
are you sure about that?
http://www.motec.com/products/plm/sensors.htm
Old Aug 8, 2005 | 03:24 PM
just because its a 4 wire doesnt make it a wideband, it's just heated.
Neil
Old Aug 8, 2005 | 03:45 PM
BB6racer's Avatar
only hondas with wideband sensors are the new cars with k series engines.
Old Aug 8, 2005 | 05:05 PM
AzCivic1.6's Avatar
i'm almost positive that the hx civic came w/ a wideband, which like pentaq said had the vtec-e.
Old Aug 8, 2005 | 05:06 PM
AzCivic1.6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastrx7turbo &raquo;</TD></TR><TR><TD CLASS="quote">just because its a 4 wire doesnt make it a wideband, it's just heated.
uhh i think heated o2 sensor are probably on all obd 1&2 cars.
Old Aug 8, 2005 | 06:17 PM
yea, most likely, especially on obd2. my 7 orginally came with a single wire type.
neil
Old Aug 8, 2005 | 11:03 PM
pentaq's Avatar
they are 5 wire sensors.
http://wbo2.com/lsu/sensors.htm
http://techedge.com.au/vehicle/wbo2/wbntk.htm
iibb6ii
May 15, 2005 08:10 PM
Monkey Fing a Coconut
Mar 16, 2005 04:23 AM
kb7709
Sep 11, 2004 06:07 AM
ludefreek
Aug 11, 2003 08:27 AM
