91 crx
Old Aug 4, 2005 | 12:45 PM
pfsbiz's Avatar
Default 91 crx cuts out / stalls
cuts out and won't start for awhile. then runs ok...then the same problem. replaced the fuel pump. still a problem. What else can I check?
Modified by pfsbiz at 4:04 PM 8/4/2005
Old Aug 4, 2005 | 12:48 PM
Magick211's Avatar
Default Re: 91 crx (pfsbiz)
Do you hear the fuel pump prime everytime you turn the key to the on postition? Could be your main relay
Old Aug 4, 2005 | 01:02 PM
pfsbiz's Avatar
Default Re: 91 crx (Magick211)
thanks for that tip... It does start eventuly. then cuts out .Is this a main relay problem?
Old Aug 4, 2005 | 01:05 PM
dj Edify's Avatar
WTF DOES THIS MEAN???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pfsbiz &raquo;</TD></TR><TR><TD CLASS="quote">cuts out and won't start for awhile. then runs ok...then the same problem. replaced the fuel pump. still a problem. What else can I check?</TD></TR></TABLE>
MORE INFO
Old Aug 4, 2005 | 04:31 PM
JaHnAbOi's Avatar
Default Re: 91 crx (dj Edify)
It isn't your "Main" relay. Its a relay for ur fuel pump only. Its located under ur dash where ur fuses are. From there you look to ur left where theres a hanging piece of plastic from "the change box" that hangs down. Behind that plastic right above ur latch for ur hood is the relay. Its pretty big. This is a problem on all older models of hondas. Due to high temperatures it cause the soldiering to be flaky. Hope that helps! PM if anything. I had the same exact problem.
Old Aug 5, 2005 | 04:22 PM
pfsbiz's Avatar
Default Re: 91 crx (JaHnAbOi)
Thank You so much..I'll check the fuel relay and get back to you... Thanks again. Tom
Old Aug 5, 2005 | 04:33 PM
Magick211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaHnAbOi &raquo;</TD></TR><TR><TD CLASS="quote">It isn't your "Main" relay. Its a relay for ur fuel pump only. Its located under ur dash where ur fuses are. From there you look to ur left where theres a hanging piece of plastic from "the change box" that hangs down. Behind that plastic right above ur latch for ur hood is the relay. Its pretty big. This is a problem on all older models of hondas. Due to high temperatures it cause the soldiering to be flaky. Hope that helps! PM if anything. I had the same exact problem. </TD></TR></TABLE>
That is the main relay you are speaking of. its two relays in one
Old Aug 7, 2005 | 11:20 AM
pfsbiz's Avatar
thanks for the info...... Is the main relay under the dash by the hood latch handle? I'm going to get this car back from my mechanic tomorrow. He can't look at it for about 10 days because he was burned real bad from a overheated car in the shop. I'm going to check this out tomorrow Thanks again.Tom
Old Aug 7, 2005 | 11:55 AM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
there is also a check ball in the pump that keeps pressure from leaking back to the tank when the car is off. when they go bad it takes a few key clicks (no starter cranking, just powering the pump) for the car to start. sometimes i can actually hear the fuel running up the lines by my rocker panel. i have also had to pull the 12mm bolt on the fuel filter to get it primed in the past.
ddubtoille
Nov 1, 2008 01:34 PM
916MINI
11
Aug 11, 2008 09:51 AM
boosted_soul_94
Aug 5, 2006 09:57 AM
Brownjd
Oct 15, 2003 09:33 AM
mercury
Jul 16, 2002 07:15 PM
