climate control light bulbs
Old Aug 4, 2005 | 12:29 PM
Reelizmpro's Avatar
Default CRX climate control light bulbs
I had some minor issues with my temp control that I had to fix and while I was in there I wanted to replace one of the blown bulbs. I found a replacement bulb from an electronics store but it's about 1/2 the size of the original one. Anyone know where I can get the original bulbs from? or how much the OEM ones cost from the dealer?
Old Aug 19, 2005 | 07:51 AM
B18C_EJ8's Avatar
Default Re: CRX climate control light bulbs (Reelizmpro)
Bump for info... Have same issue, but with clock light...
Old Aug 19, 2005 | 09:06 AM
spazz0nater's Avatar
Default Re: CRX climate control light bulbs (B18C_EJ8)
same here but the part below the temp thing
Old Aug 19, 2005 | 09:12 AM
suspendedHatch's Avatar
That's the kind of thing I collect from the junkyard when I find the dash all stripped out. Or if they are the same, I'd probably take them out of my original cluster.
Old Aug 19, 2005 | 10:40 AM
B18C_EJ8's Avatar
Just went to the dealer on lunch... $1.72 for the bulb and plastic sleeve... Just insert, twist, and you're done...
Old Aug 19, 2005 | 12:06 PM
Reelizmpro's Avatar
Default Re: (B18C_EJ8)
That's a reasonable price. Thanks for posting. I ended up going with that 1/2 sized bulb for 40 cents. I had to manually unwrap the old bulb and wrap the new bulb in the old socket but it works. Light output looks to be about the same since I pulled the bulb so that it was completely out of the socket for more light. Good to know we have options right?
Old Aug 19, 2005 | 01:31 PM
sam385's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Just went to the dealer on lunch... $1.72 for the bulb and plastic sleeve... Just insert, twist, and you're done... </TD></TR></TABLE>
do you know the part#?
i need some of these bulbs too.
skill178
Feb 3, 2014 11:01 AM
shortlid
Apr 15, 2007 08:46 AM
FakeJDMEF8
16
Dec 19, 2005 05:11 PM
Buffs8080
Aug 5, 2005 06:44 PM
kwil6666
15
Feb 17, 2004 01:47 PM
