Which one will be more dangerous for stock internals? small turbo high psi / big turbo low psi? or h
Old Aug 4, 2005 | 12:13 PM
elpiar's Avatar
Default Which one will be more dangerous for stock internals? small turbo high psi / big turbo low psi? or h
Maybe different kind of damage on the internals?
Old Aug 4, 2005 | 12:19 PM
nsxmatt's Avatar
Default Re: Which one will be more dangerous for stock internals? small turbo high psi / big turbo low psi?
Horsepower not boost is what hurts engines.
Old Aug 4, 2005 | 12:20 PM
dornon13's Avatar
https://honda-tech.com/zerothread?id=1055905
https://honda-tech.com/zerothread?id=1004578
check these out from the FAQ. Maybe they will be helpful
Old Aug 4, 2005 | 12:28 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Horsepower not boost is what hurts engines.</TD></TR></TABLE>
ON a properly tuned engine that can be the case. But I would not want a small turbo pushing incredible amount of boost and creating lots of heat and doing no good at all. Especially under long hard load conditions.
Always match the turbo to the motor.
So my vote goes to small turbo high psi.
Old Aug 4, 2005 | 01:52 PM
unusual71's Avatar
its more the detonation that'll hurt the engine. the thing is to get high boost out of a little turbo into a large engine means you'll have to work that sucker pretty hard, if you can get a high flowing intake and head work the larger turbo would be the way to go
jdjustme
Mar 9, 2007 01:05 PM
robbizza
May 21, 2006 02:17 PM
prabtej_si
Jan 25, 2005 09:02 PM
Madrat888
Jun 20, 2004 09:35 PM
earl
Dec 19, 2001 08:20 PM
