Help identify these B series cams
Old Aug 4, 2005 | 10:35 AM
2point6's Avatar
Default Help identify these B series cams
I looked for pictures and found some identification, but not for these cams. Any help is appreciated. Sorry about the picture quality.
These cams appear to have 3 rings on the raised portion of the cam and one ring each on the end
This set looks similiar to an ITR set, with 2 rings on the raised portion, but does not have any rings on the very end.
Modified by 2point6 at 11:51 AM 8/4/2005
Old Aug 4, 2005 | 10:41 AM
riceball777's Avatar
Default Re: Help identify these B series cams (2point6)
if there are no rings they they are either b16 or gsr cams
pre00 itr cams have 1 ring on both cams
00+ itr cams and ctr cams have 2 rings on the intake cam
Old Aug 4, 2005 | 10:48 AM
2point6's Avatar
Default Re: Help identify these B series cams (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">if there are no rings they they are either b16 or gsr cams
00+ itr cams and ctr cams have 2 rings on the intake cam </TD></TR></TABLE>
Thanks, but that doesn't seem to help me with these...
Old Aug 4, 2005 | 12:52 PM
G U E C O's Avatar
first pic are gsr cams
Old Aug 4, 2005 | 01:28 PM
Rocket's Avatar
Default Re: (Young Grasshopper)
Use a caliper and find vtec lobe lift and then multiply by 1.55 and see what you get.
Old Aug 4, 2005 | 02:01 PM
2point6's Avatar
The second set lobe height is...
EX: 1.390" x 1.55 = 2.154"
IN: 1.450" x 1.55 = 2.247"
Old Aug 4, 2005 | 02:12 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 &raquo;</TD></TR><TR><TD CLASS="quote">The second set lobe height is...
IN: 1.450" x 1.55 = 2.247"</TD></TR></TABLE>
Ah you need to subtract the base circle of 1.160" to arrive at lobe lift.
So you now have:
EX: 0.230 x 1.55 = 0.356" or 9mm
In: 0.290 x 1.55 = 0.450 or 11.4mm
Hopes this helps you out sir.
Old Aug 4, 2005 | 02:26 PM
2point6's Avatar
Default Re: Help identify these B series cams (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">
So you now have:
Hopes this helps you out sir.</TD></TR></TABLE>
I forgot the base circle...
Any idea what the second set is?
Thankyou for the help rocket.
Old Aug 4, 2005 | 02:37 PM
Rocket's Avatar
Ex. Seems to be GSR.
Old Aug 4, 2005 | 02:48 PM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Ex. Seems to be GSR.</TD></TR></TABLE>
Correction... second set intake is 1.404" - 1.160" = .244 x 1.55 = .378" or 9.6mm
Modified by 2point6 at 4:00 PM 8/4/2005
Old Aug 4, 2005 | 03:07 PM
2point6's Avatar
Would the base circle measurement be the same for a regrind?
Old Aug 4, 2005 | 03:12 PM
Rocket's Avatar
Nope.
You can measure the base circle with your caliper. It's going to be the min measurement.
Old Aug 4, 2005 | 03:48 PM
2point6's Avatar
Thank you very much for the information.
Old Aug 4, 2005 | 03:49 PM
Rocket's Avatar
Very coo!
Glad to see you have a caliper. Most handy thing in my tool box.
Old Aug 4, 2005 | 06:39 PM
krispyone's Avatar
good info
Old Aug 4, 2005 | 07:39 PM
boosted k20's Avatar
Default Re: Help identify these B series cams (jello24)
i just picked up a set of cams today that are the exact same ones in your 1st picture. So is rocket correct with stating that these r GSR cams?
Old Aug 5, 2005 | 06:26 AM
Default Re: Help identify these B series cams (boosted k20)
they r GSR cams
https://honda-tech.com/zerothread?id=1127535
https://honda-tech.com/zero...age=2
RustyE.G.
11
Oct 23, 2013 04:29 AM
Turbo B18C EJ6
Sep 1, 2010 08:14 PM
ipodhustle
May 8, 2007 08:35 AM
compwc18
May 22, 2005 05:05 PM
romeirome1
Dec 28, 2003 09:18 PM
